Craftsman lawn tractor burning oil
   / Craftsman lawn tractor burning oil
I found a couple video guides for Inotek engines which are really good. I'll follow along and see what I find. Thanks!
I tested compression prior to pulling the head the other day and found that I was getting 90-95psi. The only thing I had done was pull the head cover, clean the oil, and reinstall. After rebuilding, I now have 120psi! I killed the battery by leaving the switch in the wrong position, so I couldn't start it up after getting everything back together, but this morning it fired up with pep and engaged the deck with a small puff of exhaust. Should run MUCH better now!
   / Craftsman lawn tractor burning oil #13
Good news.
The motor seems to run great after it warms up. Prior to the gasket failure (the large plume), I could turn the mower on and engage the deck immediately if desired. Now if I don't let it run for a couple minutes the motor will bog down and try to die. After it's been run for a few minutes, I haven't seen any issues.
I checked the spark plug and it has black on the sides but not the spark points. I haven't done anything to the carb, but I'm wondering if somehow it could have been bumped enough to require tuning? Black soot to me suggests it's running rich but I don't see any exhaust so I expected it to be a clean plug. Perhaps these engines have some small amount of soot even when running clean?
   / Craftsman lawn tractor burning oil #15
Wouldn't black soot indicate that it's burning oil ?
I was under the impression that rich gas engine didn't procude soot unless it burned oil as opposed to diesel.
I don't think it's not burning oil at this point. I ran it for a couple hours now and the oil is pristine and at the original level. I should pull the plug after it's run for a while to see if it looks the same or if the thin coating is burned off.
I didn't adjust the valve gaps as they seemed pretty close to the correct setting. The manual gave a gap tolerance and they were within that so I didn't bother trying to exactly center the gaps.
I can't think of any other tweaks that could be made other than tuning the carb. But, since it runs fine with no backfires/surges/choking/etc, I don't want to create a broblem for something of a minor issue (I think). The only other thing I can easily do (and should anyway) is change the fuel filter.
   / Craftsman lawn tractor burning oil #17
You might add some Sea Foam to the fuel to help clean it out. Expect some white smoke when you first use it.
I have a can ofseafoam but have never used it. Any recommendations on amount to use? Does it clean the carb or just the cylinder? I manually scrubbed the piston/cylinder surfaces prior to rebuild, so hopefully it works on the carb as well.
   / Craftsman lawn tractor burning oil #19
Sea Foam will clean the complete fuel system. From the tank to the cylinder. If I remember correctly one small bottle treats 20 gallons of fuel. Using more per gallon will not have any ill effect. I filled my 5 gallon storage tank and added 5 oz. Sea Foam to it and fill the mower from it till it was used up.
I just read their web site and the recommendation seems to be 2oz/gal is a good starting place. I replaced the bowl last year when the seal failed and it started leaking but I haven't done anything else with the fuel system. I'll try seafoam first anyway.
2015 Toyota Camry Sedan (A51694)
2015 Toyota Camry...
2014 DODGE CHARGER (A51406)
2014 DODGE CHARGER...
2013 Nissan Pathfinder SUV (A51694)
2013 Nissan...
2020 International MV607 2,000 Gallon Water Truck (A51692)
2020 International...
2016 Kubota M5660SU (A50123)
2016 Kubota...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
