Massey 135 3 point
   / Massey 135 3 point
Well I flushed the system with a 50/50 mixture of diesel and hydraulic fluid then put in a new filter and fluid. I tried picking up the brush hog and it wouldn't do it so I decided to try the chain trick. I removed the top link and hooked a chain in it's place then I hooked the chain to the back of the tractor just below where the top link hooks and the tractor picked the brush hog up just fine. I had to stop there because I ran out of time. Not sure how much more I can go with this in the near future because the weather is starting to turn bad and I don't have a good place to work on it and I won't be brush chopping once snow flies.
   / Massey 135 3 point #12
http://www.tractorbynet.com/forums/...rguson35-hydraulics-wont-work.html?highlight=
Check out this thread and follow shona13 response. This is the same issue you are having.
(INOP) JOHN DEERE 544 AA WHEEL LOADER (A60430)
(INOP) JOHN DEERE...
1992 Norris Long Basket Trailer (A60460)
1992 Norris Long...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
CATERPILLAR CB13 SMOOTH DBL DRUM ROLLER (A60429)
CATERPILLAR CB13...
500BBL WHEELED...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
