O my, I am comfused
   / O my, I am comfused #311
Nikko,
I recently posted about the massey gc1715 as a lawn mowing machine. Now I'll talk about it as a tractor.
I have a long large concrete driveway with a considerable slope to it. I also have a front patio and rear patio of concrete and about 125 feet of 5 foot concrete sidewalk . . and we get wintet drifting too. So the GC will be using its bucket and/or bucket and snow edge often. And a lawn tractor will be equipped with a snowblower as well. My desire is to keep the fel on all winter . . so no $4500 snowblower for the gc1715. Too many snows will be bucket and snow edge. (Plow is too hard on concrete).
Then there is the brochure. Can you actually tell how much wdight the fel can lift? I can't. So on two different days I actually measured.
1st time I previously wrote about and it was 864 pounds of actual concrete I moved on pallet forked effort.
But I did it again yesterday in very controlled conditions.
Fel minus bucket.
Add 77 lbs for the quick attach
Add 115 lbs for the forks
Add 26 pounds for a cheap pallet
Add 63 concrete edgers scaled at 15.3 pounds per piece (963.9 lbs. Of concrete).
At 3100 rpm I was able to pick it up and move it 50 feet and set it back down. But then after a slight drizzle and a 10 minute rest . . I was not able to re-pick it up to take to destination . . so I removed 2 then 2 and finally 2 more edgers then making it a total of 57 edgers (872.1 pounds)
A dl95 loader on my gc1715 at 3150 rpm lifted and transported 200 feet up and down an incline the following
77 lbs + 115 lbs + 26 lbs + 872.1 pounds of payload. Total weight = 1090.1 lbs. Plus some rain water and 2 earth worms :)
I'd say with a mini grapple I'll be able to haul a good sized log or a biiig biiig bucket of rock :) Don't you agree?
Also . . Consider the 3 pt carrying capacity is even larger. Lastly there's another type of grapple that is made for the same quick attach unit. It is a "vertical grapple" capable of grabbing water heaters or tree trunks and picking them out of the ground. That doesn't mean eight inch diameter trees . . But certainly 3 or 4 inch diameter rooted trees.
A good scut . . is capable of tractor performance . . over and over again. Its not a baby tractor . . at least not when the fel can produce what my measured weights show.
Now a gc1705 would be a smaller number because it us 2.5 horses smaller. At 2600 rpm I couldn't lift thw same as I could at 3000 or 3150 rpm. The GC1715 cost me $1200 plus tax more than the gc1705. For that difference I got superior seat with added spring suspension comfort and better fit of seat. I got a rear light. I got more lifting power and mire mud and rear pto power . . And kept all the advantages of a great lawn cutting unit and moving, digging, wood handling tractor too.
And even with the quick attach, forks, and future grapple and remote and all sales tax and snow edge and tire loading I will be less than $18,500 and insurance for 5 years and have 3.49% loan interest rate.
Thats everything nikko . . Everything
Now I'll sit back and listen as everyonr else says you need bigger bigger bigger Nikko. And your decision is your own . . I simply presented my needs and slopes and etc. Etc. And why I chosr the way I did. Your decision is up to your needs.
Yes, I have a hard time seeing where the OP would need more than this. A bigger CUT may cost the same, but he will never use the extra power, and it will beat up the lawn. Other that two machines, this seems the best thing, from what I can tell of the OP's needs.
   / O my, I am comfused #312
Good to know Axle. For comparison, I can pick up >3000 pounds at idle regardless of if it's raining or not. And my tractor cost $22K w quick attach loader, tooth bucket, snow bucket, forks, filled rears, rear remote and tax.
And your tractor dances on grass like Fred Astaire! :laughing:
   / O my, I am comfused #313
Mine don't. If the yard is wet, it smashes the poop out of it. But I don't operate the tractor on the yard much when it is wet either. Not as bad as the old Utility tractor I used to have with R1 Ag tires on it.. that thing would leave tracks in the field that would last for years!
   / O my, I am comfused #314
There are many variables to lawn health and compaction. Type of soil and type of grass both make a difference . . But a big variable is fetilizer or lack of it. I learnef long ago from a vety bright "hidden diamond" of a farmer . . No anhydrous ammonia and no fertilizer . . Just amendments and herbicides. When worms are close to the surface . . You have no problems (in general) with compaction. I followef his lead and have had wonderful lawns for many years since. Of course if you drive a skud steer on wet grass of a tractor with ag tires . . You'll rip the sod rigjt out of the ground . . But that just common sense of course . . kind of like behwading is bad for your health :)
   / O my, I am comfused #315
More like William "The Refrigerator" Perry dancing across the goal line on AstroTurf :thumbsup:
   / O my, I am comfused #316
More like William "The Refrigerator" Perry on AstroTurf :thumbsup:
Not if you can lift the front end with one hand.
I met Willie Roaf the 1st round pick for the Saints in the 90s when he was new . . there was no part of him I could lift . . My gosh he was an athletic specimen. When Richard Dent stood next to him after a scrimage . . Dent looked small.
   / O my, I am comfused #317
Axle, can you put your forks on the 3 pt and do a real world test? Your 3pt is rated at the eyes compared to most that are rated 24" behind the eyes. I'm curious how that translates I a real world test?
Well gentlemen i BOUGHT A GC1720 with mmm! After lisenting to everybody and thinking about it, reading more and watching more and more videos on youtubes and of videos you guys posted on this forum. Thankyou for all your help! I finished the paper with it today 19,000 out the door. Purchased out of state so no sales tax also :). Will be at my home next week sometime.
Axle and glade I appreciate you guys helping alot as also for everyone else sorry for the not mentioning names didnt wanna sound like grammy winner. I wish i could of persuaded my wife for 2 machines, but couldn't.
Looking forward to the delivery and doing upgrades lil by lil :). Led light bar, teeth on the bucket.
Can I ask the dealer to load my tires? Is it normally a free cost?
   / O my, I am comfused #319
I thought the dancing comment was directed at the tractor? It's the zero turn that I can lift with one hand.
   / O my, I am comfused #320
Congratulations! I think you'll appreciate the backhoe. Most have paid for tire fill but some got it at no additional charge . Can't hurt to try! :thumbsup:
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2018 Ford F-150...
IRGC80 Lifted Electric Golf Cart **Unassembled**(New/Unused) Plugs into standard 110 outlet , Com... (A59225)
IRGC80 Lifted...
2350 (A58376)
2350 (A58376)
2019 WABASH DVLSHPC 53FT DRY VAN TRAILER (A59575)
2019 WABASH...
