Rotating HD Tree shear/puller ~ Got one?
   / Rotating HD Tree shear/puller ~ Got one? #1
Coyote machine
Super Member
Southern VT
22 SANY SY 50U, '10 Kioti DK 40se/hst KL-401 FEL, loaded tires, KB-2485 bhoe, Tuffline TB160 BB, Woods QA forks, MIE Hydraulic bhoe thumb & ripper tooth, Igland 4001 winch, & GR-20 Log Grapple. Woods BBX72" Brush Mower. Diamondplate aluminum canopy
Hi TBNers,
Anyone have one of these? 12" HD Rotating Tree Shear Attachment
I'm thinking of getting this attachment to pull trees, line them in a row, cut off the root balls, then stack and burn, or give away the stalks, and dump the stump/rootball sections.
Any thoughts, reviews, comments etc. greatly appreciated.
TIA,
CM
   / Rotating HD Tree shear/puller ~ Got one? #2
They look solid!!! Let us know what you think if you get one. The only bad thing is it weights over 900lbs - take a chuck of your loader lift capacity, but it sure would be handy!
They have one for several hundred $ less that weighs 760#s or so, with a smaller cylinder. The big one has 30K#s of crush force!
My loader can lift around 2700#s, so not too much of a concern, but nearly 1000#s is a lot of tool to carry, not including a tree in it's jaws!
On the other hand, it looks awesome strong.:thumbsup:
   / Rotating HD Tree shear/puller ~ Got one? #4
I noticed the 30K crushing force and thought that was impressive! Should be able to "snip" most of the smaller limbs off in seconds to make transporting easier. Heck, with a 12" capacity you can "snip" logs into firewood!
If you end up getting one we need a video - like to see that in action!
   / Rotating HD Tree shear/puller ~ Got one? #5
Maybe I got the wrong link? The link is for a shear not a puller. Looks to me like that thing will quicky crumple with the forces perpendicular to the blade needed to pull up a tree of any size.
Luke, It's a rotating tree sheer and puller. The blade/jaw rotate to horizontal from vertical, manually. Yes, it can sheer trees, but it can also grab them and pull them out of the ground, like other tree grabbers that are not also for shearing. At least that is my understanding of the purpose/mechanism
Which brand type did you buy? I got interested in all this from a thread you posted recently, IIRC.
I'd be interested to know why you chose the brand unit you did, if you don't mind sharing that here.....
Thanks,
CM
   / Rotating HD Tree shear/puller ~ Got one? #7
Sure but my experience is limited to Internet research and the one I own. It's a Bradco Large Jawz. I have thought how nice it would be to hydrauliclly rotate it like a feller-buncher.
My MX4800 has roughly similer capabilites to your Kioti (I know you may not feel the same). The forces to will put on the attachment will be quite large. You'll find that at the lager tree size you will lift and drive forward to pull up a well anchored tree.
Got to run will write more later...
OK. I found another tree shear that does rotate hydraulically- probably big $$, but I don't know yet. It will only handle up to 10" trees and weighs around 550#s, instead of the 960+ of the Titan. I do have some concerns about overall weight taken from the loader's lift capacity. Too heavy a tool defeats some of the purpose it serves, especially when one of it's main features is lifting, in addition to cutting.
From the owner's manuals I've read the shears want a cut to be made at ground level, NOT at several feet above. This sort of defeats my 'plan' to cut off tree, then lift the root ball and 'stump' and remove each from the work zone.
I like the tree grabber idea, BUT I would like to be able to cut off the root ball without having to whip out a saw and do it as a separate operation. The shear allows one to drop the tree and cut it into needed lengths without stepping off the tractor, assuming one gets the hydraulically rotated unit.
I think it might be possible to turn the shear into more of a grabber by adding a short section of poly pipe over the blade when lifting smaller trees out of the ground, then removing it when the time comes to cut the root ball off and dice up the tree into desired lengths.
If you'd be willing to PM me the name of the dealer you bought your puller from and what you were able to save doing so, I'd appreciate that. If not, that's OK too.
BTW, I'm not familiar with your tractor model or it's capabilities, so I suspect you're right about both brands having similar capabilities and limits.
My Igland log grapple is under 400#s, the jaw opens to around 40+ inches, and it allows me to do a lot of work a heavier/bigger foot print one would not. I prefer well built compact attachments that allow for maneuverability, when possible/affordable.
   / Rotating HD Tree shear/puller ~ Got one? #9
Talk to Drew at Townline. He made a mistake pricing mine even after I questioned the price so he then honored that price even after I offered to pay the correct amount. Be sure you get the "brick guard" that keeps the tree from getting acquainted with your cranium. The ones pictured on EA don't have this.
   / Rotating HD Tree shear/puller ~ Got one? #10
I went with the Jawz for several reasons.
I wanted both sides to articulate. The jaw are on the same circuit so they self-center. So it is ok if the tractor is a little off center. With only one moving jaw the loader may get torqued to the side a little as the jaw closes. You then are gonna put these huge forces on the loader with it twisted some which seems might put the loader arms at risk.
These things are primarily designed for skidsteers which are easier to position on center and have more robust loaders.
I also decided the wavey jaw pattern had some advantages in versatility. Just my intuition.
Lastly, I wanted stout greasable hinges and protected cylinders. You are operating these down in the dirt so frequent greasing seems prudent.
I also use it to move and place granite rocks for walls etc. Here especially it would be nice to have hydraulic rotation.
(2) SQUIRREL CAGE FANS (A54757)
(2) SQUIRREL CAGE...
Pallet of 10 Chains and 5 Binders (A54865)
Pallet of 10...
Mini Standing Fire Pit (A55758)
Mini Standing Fire...
2009 Ford F-250 Ext. Cab Enclosed Service Truck (A55788)
2009 Ford F-250...
2005 Ford F-150 Pickup Truck (A54814)
2005 Ford F-150...
TMA (A49461)
TMA (A49461)
