Rotating HD Tree shear/puller ~ Got one?
   / Rotating HD Tree shear/puller ~ Got one? #31
The only thing Ive ever done was uploading video from my phone to YouTube and then copy-and-paste the YouTube link into my post.
   / Rotating HD Tree shear/puller ~ Got one? #32
This is probably the easiest way to do it.
A GoPro works great and everything goes fairly smooth with YouTube since they are pretty much a "standard".
You certainly can use your phone however if you find it easier.
Thanks and let us know if you need some assistance.
   / Rotating HD Tree shear/puller ~ Got one? #33
UPDATE!
Tree Shear arrived yesterday. YEAH. It was on a wood pallet and framed with metal angle iron to form a cage. It was on it's back with the QA and protection grid on the pallet and the shear facing upward. It was well secured to the frame and the frame corners were bolted together and the frame was wired to the shear to keep it together.
All, in all, an impressive way to contain it from damage.
I greased all the pins, YES there are zerks at all crucial points where they need to be. The 5" cylinder is MASSIVE, as is the entire unit. I installed my two male end connectors onto the 3/4" hydraulic hoses, and routed them through the wire grid above the QA plate. This is going to take further thought so I don't end up doing damage to the hoses or end connectors on the torque tube of my loader. The hoses are probably long enough, BUT I have to take into account full range of the entire shear in curl and extend, as well as the ability for the hoses to follow the 'swing' from horizontal to vertical, without any pinch points or strain on fittings / hoses.
The shear works great, BUT one wants to make absolutely sure it is locked into the QA before moving the tractor - obviously; but it bears mentioning due to it's weight of nearly 1000#s!
Once secured and greased, and some Fluid Film or dry graphite sprayed on the shear blade to enhance smooth cuts, away one goes; taking into consideration that there is a serious need for ballast to be used when the shear is on the loader arms. I happen to have my 700# Woods 6' Brush hog on currently. It's adequate, but not enough to be completely safe, especially if turning quickly, etc.
The shear opens and closes somewhat slowly compared to say my grapple jaws or my snow plow swing side to side etc., BUT this is a good thing from the standpoint of learning curve with a new piece of equipment.
Higher RPMs will render the close/open speed somewhat higher, but maximum capability would be better on an actual skidsteer, I imagine, due to their higher pump output.
I can't say yet what the maximum tree diameter that could be cut would be, even though the specs call for 12". I have worked my way up to about 1/2 that so far as I get accustomed to the operation of the shear and gain skill at using it. I will say it does whatever I ask of it so far.
One notable drawback is there is no available manual for the shear - Titan says they are working on one. I sure hope so. This is a potentially deadly piece of equipment; and not having instructions on use/maintenance is totally nuts in my opinion. I can say that there are other shear manuals I've looked at online; and this is a good way to familiarise oneself with the basics of operation/safety, etc.
More later.
Thanks,
CM
Just wanted to say Thank You for your business!!! If there's anything you need, let us know. I would love to see some video as well. A youtube link would be great!
Thanks again!!! :thumbsup:
You're welcome. And yes I want to do some sort of video of the shear, soon as I can get to it.
I would like to know when you anticipate having an owner's manual for the shear? It is a top priority from my standpoint.
Thanks,
CM
We can email a PDF copy if that works for you.
That would get me going- but I would like a hard copy for my files on my equipment.:thumbsup:
I'll PM you my email address- which you should already have from the sale- but I'll do it anyway.
Thanks,
CM
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
2006 Ford F-550 4x4 Altec TA37M 37FT Bucket Truck (A55852)
2006 Ford F-550...
2006 V.E. ENTERPRISES 130 BBL STEEL VACUUM TRAILER (A53843)
2006 V.E...
JOHN DEERE 410L BACKHOE (A52706)
JOHN DEERE 410L...
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
