PTO shaft "stub" broke off
   / PTO shaft "stub" broke off #11
when you unbolt the back cover I think the shaft will pull out, looks like snap ring and a bearing plus the cover is what holds it in place
This is my hope
   / PTO shaft "stub" broke off #13
75 years ago on tractors they were simple. 3 or 4 bolts and the shaft, retainer, bearing, etc all came out. Hard to believe they would go backwards on technology.
Hope its simple your you. Have no experience doing that on any kubotas. Subscribed to see what the cause was once you get er repaired
   / PTO shaft "stub" broke off #15
The Lxx40 WSM states to remove the PTO shaft cover; remove the PTO bearing case mounting bolts and draw out the PTO shaft with the bearing case; remove the internal snap ring; tap out the shaft toward the front. On reassembly, it says to replace the lock nut with a new one if the lock nut was removed and be sure to stake firmly, install the slinger firmly, apply grease to the oil seal and install it noting the proper direction. The lock nut torques to 108 to 145 ft-lb before staking. The bearing case mounting screws torque to 17 to 20 ft-lb.
   / PTO shaft "stub" broke off #16
Here is the stub that broke off
Bad stub, no diner!
446827d1447118144-pto-shaft-stub-broke-off-image-3820468240-jpg
Thank you! It's early, but "stake" firmly. I assume this means set it in place. But I don't want to assume. So can this be clarified? Overall it seems straight forward.
   / PTO shaft "stub" broke off #19
Staking to me means deforming the metal. As an example to stake a nut onto a bolt you deform the metal by raising a burr between the nut and the bolt. An automatic center punch, or regular centerpunch and a hamner. To stake a front sight on a 1911 pistol, you need a staking tool that smashes the sight into the underside of the slide. To stake a spring tunnel, means deforming metal so the part cannot migrate out...
So when they say stake a locknut, to me that means raise a burr so it cannot be moved. Others may wish to clarify here.
Staking to me means deforming the metal. As an example to stake a nut onto a bolt you deform the metal by raising a burr between the nut and the bolt. An automatic center punch, or regular centerpunch and a hamner. To stake a front sight on a 1911 pistol, you need a staking tool that smashes the sight into the underside of the slide. To stake a spring tunnel, means deforming metal so the part cannot migrate out... So when they say stake a locknut, to me that means raise a burr so it cannot be moved. Others may wish to clarify here.
Ok, mKes sense. If I can't do that part, I may run that to the dealer. See if they can throw me a bone and stake it if I bring them the part.
LOAD OUT AND SHIPPING (A51573)
LOAD OUT AND...
EZ-GO MPT 1000 Electric Utility Cart (A51691)
EZ-GO MPT 1000...
2008 VOLVO EC460CL (A52472)
2008 VOLVO EC460CL...
2016 Ram 4500 Chassis Truck, VIN # 3C7WRKFJ7GG229313 (A51572)
2016 Ram 4500...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2024 JOHN DEERE 8R 280 LOT NUMBER 8 (A53084)
2024 JOHN DEERE 8R...
