Hard Startup
   / Hard Startup #11
Check fuse, wiring, relay.
I don't have a Kubota, but my tractor has a timer for the glow plugs when you turn on the key.
My glow plugs quit a few years ago and I had a bad timer.
   / Hard Startup #12
Did you check the connections on the relay?I had a similar problem when I had an L3240 and it was just a bad connection which was easily fixed.Good luck.
   / Hard Startup
So, I think I'm on to something.
In the attached picture, if I probe the large red wire, it is 12V always.
The large Black/Red wire (on the right) never goes hot...
It *should* be hot once the key is on and then go back to nothing when the GP light goes out, right?!
I also get about 0.5 ohms between the black wire here (at the relay) and the positive side of the glow plug.
Interestingly (FRED!!!!!), the terminals are huge on the socket, but not on the relay.
Also interestingly, the relay is definitely clicking. I just tested it on the bench, and it tests fine.
I guess I have a bad connection between the terminal and the socket. That seems *impossible* that taking the socket in/out multiple times would give me ZERO connection.
FRED--you said you replaced your relay with a Bosch. Any identifying marks or PN? I can pick one up tonight, but saying "I want one of these where these two terminals are "bigger"" just doesn't seem like fun.
I also checked all the fuses. All were fine. Again, the WSM's wiring diagram makes reference to a GP fuse, but I haven't the foggiest where it is.
Any advise?
   / Hard Startup #14
Somebody at the factory screwed up just like mine. Correct on your relay logic. The one that never goes hot is for the 4 glow plugs and if you ohm the wire you will get resistance on one glow plug times 4. Your glow plug fuse obviously is fine if you have power to the wire that you checked.
I work On Volvo cars for a living so I used Volvo #9494448. It's a VERY common relay in the auto industry. Most parts stores will stock the one you need. Make sure the relay you buy has an internal resistor to protect the device that controls it. Most do these days. Here's one that does.
V23134J0052X429 (1-1414147-0) Maxi Relay | Buy Online | Chief Enterprises
Check the relay next to it for the fuel shutoff solenoid I bet that's wrong also but draws so little amperage that is hasn't bothered yet.
Both mine were wrong.
Regards( and regrets for buying my Kubota), Fred
   / Hard Startup
Holy crikey. That's a spendy one.
I bought a couple on ebay.
If I ohm from that big black wire to ground, I should get 0.9/4 ohms (parallel resistors).
It still blows my mind that I'm not getting a connection on the output, despite the wrong tab size. I'll probably muck with the terminal and (hopefully) make connection with my stock relay. Then either open it up to swap them later, or wait for this to happen again.
Hopefully.........
   / Hard Startup #16
0.9 divided by 4.
I personally like to use an amp clamp. All you need to do is use your amp clamp around that big wire then jump the terminals 30 (battery) and 87 (load). I'm thinking they draw almost 80 amps and drop down fast as they warm up.
Regards, Fred
   / Hard Startup
Just for closure.........
I have "the right" relays on order. They are used, but the Volvo ones that Fred used. New was like $38 and used was $5. I'm sure I could have digikey'd one up after calculating the load, knowing the socket type, measuring the terminal widths, etc. etc. So screw it, used is fine (likely has a rating of 10 million cycles).
EARLY this morning, I went out and bent the terminals (both big ones) a little bit with a screw driver. BINGO, voltage on the far side of the terminal. Also voltage at the GPs. Fired up after 2 "cranks".
The terminals are SORTA like this one QCF-2.jpg except it's wider (probably a 280 series) and the "tongue" comes up from the bottom, instead of this one going down from the top. Anyway, the point I'm trying to make is that I bent that "tongue" out, as opposed to the "ears" in (like you would on a standard spade receptacle)..
Thanks for turning me to my GPs. I was entirely barking up the wrong tree. Solution was nicely priced, as well.
   / Hard Startup #19
Yes those Volvo relays were used for over 10 years and even though we replace them as a maintenance thing when doing electric throttle replacements and secondary air pumps I don't think I ever had one fail outright.
Glad you got it.
Fred
   / Hard Startup
Glad you got it.
It feels good to learn and understand the problem and solution, as opposed to just throwing parts at it. Extra sweet when it's free or cheap.
Similar item is the re-circulation door on our Dodge Charger.. Windows kept fogging up, regardless of AC use, etc. Come to find out the drive shaft breaks off the re-circulation damper. IIRC, it's one of those "you can't buy just that" type of deals. Anyway, the fix is a small screw and some 5 minute epoxy. Solution is reasonable and makes sense given the symptoms.
Obviously the internet makes these things awesome. I watched a youtube video on how to replace the headlight on our other car (Honda)......you know, THROUGH THE WHEEL WELL. Arg.
2012 DRAGON 130BBL VAC TRAILER (A58214)
2012 DRAGON 130BBL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
CATERPILLAR 305 CR EXCAVATOR (A60429)
CATERPILLAR 305 CR...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A56438)
Neckover GL24-2-7K...
SHOP MADE MANIFOLD TRAILER (A58214)
SHOP MADE MANIFOLD...
2022 BROCE BW260 SWEEPER (A60429)
2022 BROCE BW260...
