IslandTractor
Super Star Member
- Joined
- Sep 15, 2005
- Messages
- 16,647
- Location
- Prudence Island, RI
- Tractor
- 2007 Kioti DK40se HST, Woods BH
Nobody has mentioned Kioti- maybe they don't make a machine large enough for what you want to do? I am a die-hard Kubota lover, but were I in your situation, I guess I would be open to any and all. Also, cab or no cab will come up. If you are going to be working in nasty weather, then cab. Working with a post hole auger, maybe not, unless you go with a hydraulic auger on your FEL like a skid steer would use. If you will be drilling a LOT of holes, then give that STRONG consideration. It'll cost a lot more, but after 100 holes, you'll be glad you did. They also make hydraulic post drivers for SSQA use. All this sounds like fun!
Unless the OP has a very fat wallet, he will eventually face the sticker shock associated with JD and Kubota. That is the time to start considering Kioti and Mahindra, both excellent tractor brands that make machines capable of the tasks he listed. I'm more familiar with Kioti having owned two but Mahindra is also a great tractor. In the Kioti range the decision would be whether to go with the NX range (45-60hp) with HST and a loader that lifts 2700lbs to full height or the larger RX range which goes up to ?90hp but does not have HST. Both can be had with very nice cabs and both are many thousands less costly than the JD or Kubota equivalent. The compromise is not in the quality of the tractor but rather the dealership network. Kioti and Mahindra are very well established manufacturers but their dealer networks are small compared to JD and Kubota.
