Sneak Peak at New 2016 Yanmar's
   / Sneak Peak at New 2016 Yanmar's #11
2016 Yanmar Premium Deluxe Series: List Prices. ( Dealer Prices Will Vary )
YT347 47HP Rops Tractor List Price $33,000.00
YT347C 47HP Cab Tractor List Price $41,125.00
YT359 59HP Rops Tractor List Price $35,000.00
YT359C 59HP Cab Tractor List Price $43,250.00
YL610 Yanmar Front End Loader List Price $5837.00
Not Bad for a Deluxe Premium Tractor !!
Of course these are Manufacture List prices and Dealer prices will vary.
All prices are subject to change.
Certainly interesting. I'm very curious how Yanmar is meeting Tier IV regs with these engines?
   / Sneak Peak at New 2016 Yanmar's #12
The metallic red paint is pretty sweet, but I imagine that is only on the "show" models.
Like the shape of the cabs, not so sure on the angular "transformer" styling of the nose/headlights.
Awesome that they are offering a front PTO/3pt from the factory in that size class (YT3).
   / Sneak Peak at New 2016 Yanmar's #13
What would you use that front-mount PTO/3pt for? Snowblower is all I can think of. Could you have an FEL and the front 3PT setup? Clearly you couldn't have anything mounted to it while the FEL in installed, but I wonder if the two are mutually exclusive. I wouldn't trade an FEL for front 3PT/PTO.
   / Sneak Peak at New 2016 Yanmar's #14
Snowblower, mower (mow BEFORE you run it over), forks, hay rake (rake hay over to the side, then bale it), landscape rake, sicklebar mower, etc, etc, etc.
Aaron Z
   / Sneak Peak at New 2016 Yanmar's #15
Aaron Z
Sounds great except all the attachments I currently have wouldn't work. They'd all be on there backwards! No big deal. As long as I'm dreaming about a new machine, why not throw in all new forward-facing attachments?
   / Sneak Peak at New 2016 Yanmar's #16
Bush hog would work, 3 point forks would work, landscape rake, back blade, should work (if they can spin 360 degrees), snowblower would work.
Hay rake, sicklebar mower, finish mower, etc would need some work (finish mower could be as easy as pulling the 4 bolts for the gearbox and spinning it 180 degrees, then switching the mounting brackets to the other end).
Aaron Z
   / Sneak Peak at New 2016 Yanmar's #17
Aaron covered a lot of it.
Snow blowers, plows and sweepers of course, but cutting implements of some type are the among most common usage. Many flail mowers out of Europe come with bi-directional mounts.
Also commonly used for front mounted carryalls and counterweights.
I dont know about the Yanmars, but most front 3pt that Im aware of, have arms that fold up out of the way (or easily remove) for loader and front clearance when not needed so its not an either/or option.
   / Sneak Peak at New 2016 Yanmar's #18
Thanks for sharing the pics of the pre-production tractors.
   / Sneak Peak at New 2016 Yanmar's #19
Would it be less confusing to say that the front pto has to turn in the same direction or the opposite direction of the rear pto?
   / Sneak Peak at New 2016 Yanmar's #20
It would spin in the same direction when facing it (ie: standing in front looking at the PTO or standing in the back looking at the PTO).
Aaron Z
SAKAI SV544 SMOOTH DRUM ROLLER (A52706)
SAKAI SV544 SMOOTH...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A55301)
2023 NEW HOLLAND...
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A55758)
2004 Fleetwood...
2021 HAMM HD+9I VO SMOOTH DOUBLE DRUM ROLLER (A52706)
2021 HAMM HD+9I VO...
2011 Ford Escape XLT SUV (A55853)
2011 Ford Escape...
2012 GMC Acadia SUV (A55758)
2012 GMC Acadia...
