Electric wood splitter - anyone using one?
   / Electric wood splitter - anyone using one? #1
JRobyn
Elite Member
Middle TN
Kubota L4330HST
I surprised myself that I didn't check for opinions on here first, but we just ordered a new 22 ton electric wood splitter. Wife does the splitting, but she HATES any engine that doesn't start easily, and I am sick and tired of having to tear down the ethanol-fouled carburetors in all the small engines every season. We usually only burn stuff that's a max of about 14" or 16" dia., so I figured a modest-sized electric would be a good idea. I really thought I'd opt for a 5-8 ton with a 1-2HP motor. Until I saw the Swisher L22E. It appears to be built on the same frame as their 22T gas-powered, but has a 2HP motor and 2-stage hydraulic pump. Supposedly cycles in 13 seconds.
If we really NEED a gas-powered one off in some remote corner of the property, each of her brothers that live within a mile or two have one. Of course, they usually won't start when needed.:rolleyes:
I'll let y'all know how it does in real life when it shows up next week.
- Jay
   / Electric wood splitter - anyone using one? #2
A had a homemade electric wood splitter, and didn't like it. I put a Honda gas motor on it and haven't regretted it.
   / Electric wood splitter - anyone using one? #3
Nothing wrong with electric. We have one that was converted. It's nice to spit in the warn shop while having a fire going without dying of CO gasses.
I don't like the little electric ones. But ones actually built like a full framed and have an electric motor sized accordingly....really nice. Electric is cheaper than gas, less maintenance, quieter, and easier to start. Only downside is being tethered to aa cord. Which is fine with me because I don't like dragging the splitter along to the woods. I haul the wood home to split.
4570man: what didn't you like about yours?
   / Electric wood splitter - anyone using one? #4
The biggest problem was I didn't have a tractor at the time which made it extremely difficult to bring the wood to the splitter. The second problem was it was 220 volt operation. I need to split my grandpas wood, and I split my wood at an abandoned warehouse owned by my uncle. I don't have 220 volt power at either place.
   / Electric wood splitter - anyone using one? #5
The one we converted is 240v 3ph running off a vfd. Yea, not having power would be a problem.
But another perk, especially with a 3ph running off a vfd, no one asks to borrow it.
I saw several of the larger electrics advertised with 240vac motors. So I was pleasantly surprised that the Swisher is advertised as 22T and 13sec cycle time despite that it comes wired for just 120vac. It does require a 20a circuit. I COULD have wired up a 240 outlet back by the wood shed, but then my F-I-L across the field wouldn't have been able to use it at his place. I do recognize that it would be more efficient if I rewire it (which is possible) for 240, but we'll see how it does wired for 120.
- Jay
   / Electric wood splitter - anyone using one? #7
Got any links to that splitter. I couldn't find any info. Numbers aren't adding up.
22t rating tells me.its a 4" diameter cylinder. And 13 sec cycle tells me 11gpm 2-stage pump. Pretty common setup there.
Only issue is it requires 5hp for that pump. Not something a 120v 2hp motor can spin.
Maybe they are banking on the fact that it's not 100% duty cycle, and electric motors can make alot more HP than rated, just not continuously without toasting themselves. Most splitting requires less pressure (and this less power) than the max rating of the system. But if it really is an 11gpm pump with that 2 HP motor, I'd be afraid to split a load of something difficult like white elm.
   / Electric wood splitter - anyone using one? #8
My electric splitter could match that rating, but I had a 3 hp motor on it.
   / Electric wood splitter - anyone using one? #9
Not without either:
1: smaller cylinder
2: less pressure/tonnage
3: working the motor beyond 100% on thought stuff
   / Electric wood splitter - anyone using one? #10
Link:
LS22E Timber Brute Eco Split - 22 Ton 120 Volt Electric Full Frame Log Splitter - Swisher
Bruce
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A54811)
Miller Trailblazer...
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
2016 Isuzu NPR Landscape Dump Truck (A51692)
2016 Isuzu NPR...
2004 JOHNSTON STREET SWEEPER (A54313)
2004 JOHNSTON...
2007 KUBOTA M9540 TRACTOR (A53843)
2007 KUBOTA M9540...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
