Rubber cutting edge for bucket. Snow plow.
   / Rubber cutting edge for bucket. Snow plow. #11
I was looking at it yestersay. Let us know with a small review what you think. I decided to get a full snow blade for the FEL since I live in the snowbelt. But we got only a light dusting thus far.
   / Rubber cutting edge for bucket. Snow plow. #12
1. What kind of snow blade did you get for your fel ? I had planned to build something that could work with my quick attach. The snow edge I ordered is an alternative to that plus gives me slush and "broom" type abilities.
2. In our area of western wi . . We haven't had any snow yet. That snowedge product arrived and is heavier duty built than I expected. Its 70+ pounds without packing materials. I've got "a lot" of incline/slope based concrete to use it on . . So when the white stuff comes it will get a workout :)
   / Rubber cutting edge for bucket. Snow plow. #13
It's a 60" snow blade with hydraulic angulation mounted on the DL 95 loader. It was custom made however they have templates for DL100 / DL95 loaders that they can make a snow blade for either or manual or with hydraulic angulation. I have mine setup to work with a diverter valve so I can angulate it as I need. I'll post some pics of it tonight or tomorrow. The unit is built like a tank and probably need some ballast on the rear. I have filled tires and backhoe on for plowing. Did not have a chance to use it yet since not much snow.
Yes I do like the plastic snow edge to protect the drive way. Thinking of making some plastic shoes for my plow to be a bit easier then metal on it.
   / Rubber cutting edge for bucket. Snow plow. #14
I had planned on using a 54 inch blade if I went to a plow concept just because a fel with a plow is a little easier to "spring" the arms compared to a frame and hitch situation.
I think you're smart to have a 3rd function or diverter . . As angulation from the seat is much preferred in my thinking.
I assume you pin it on?
I'll be interested in sering your idea.
   / Rubber cutting edge for bucket. Snow plow. #15
   / Rubber cutting edge for bucket. Snow plow. #16
Bolt a piece of oak, or treated 2x4, across the length of bottom of the bucket, right behind the cutting edge.
Drill holes and recess stove head bolts to hold it on.
It will last all season, and will do no damage to your pavement.
You could also put a piece on the back, if you need to let your bucket float.
   / Rubber cutting edge for bucket. Snow plow. #17
I bought some 1x5" UHDPE for other projects several years ago but I'm guessing it would make a perfect blade edge for concrete. It's nearly impossible to sand and makes great "gliders" over concrete floors. The wear resistance is phenomenal and it's slippery (Low coefficient of friction). Just bolt a slab of that between your bucket and wear blade with it extending past the wear blade. I'm betting that's what they use on those expensive add-ons. If you're handy with a welder, you could make your own clamp-on holder for the UHDPE.
I bought mine off eBay but like I said, it's been a few years. But it seemed there were a lot of sellers of the stuff and they were practically giving it away.
   / Rubber cutting edge for bucket. Snow plow. #18
I bought some 1x5" UHDPE for other projects several years ago but I'm guessing it would make a perfect blade edge for concrete. It's nearly impossible to sand and makes great "gliders" over concrete floors. The wear resistance is phenomenal and it's slippery (Low coefficient of friction). Just bolt a slab of that between your bucket and wear blade with it extending past the wear blade. I'm betting that's what they use on those expensive add-ons. If you're handy with a welder, you could make your own clamp-on holder for the UHDPE. I bought mine off eBay but like I said, it's been a few years. But it seemed there were a lot of sellers of the stuff and they were practically giving it away.
That's a really good idea about the UHDPE. Wish I'd thought of that!
Several years back I used 'plastic lumber' from recycled plastic. Ripped a piece of 1"x6" in half and bolted it on in place of the cutting edge. Works well but can't really comment on wear as it only snows here occasionally. (Couple of inches every few years. )
Terry
   / Rubber cutting edge for bucket. Snow plow. #19
What is UHDPE . . Is it s hard pladtic or s recycled vinyl or ??
How is it sold . . By the strip or block or ??? When it gets 20 degrees or lower does it get brittle or hard or "stiff spongy" ???
   / Rubber cutting edge for bucket. Snow plow. #20
Just a thought....... rather than spend over $300. for the plastic edge...... the larger buckets already have holes drilled into the lead edge.
Some carriage bolts and a 2 x 6 treated board & you have much the same tool for a tenth of the cost.
2025 78in Rock Bucket Skid Steer Attachment (A50322)
2025 78in Rock...
91013 (A48082)
91013 (A48082)
2015 Ford F-150 4WD (A51039)
2015 Ford F-150...
2008 CATERPILLAR 345CL EXCAVATOR (A51242)
2008 CATERPILLAR...
INGERSOLL RAND COMPRESSOR (A50854)
INGERSOLL RAND...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
