the old grind
Elite Member
- Joined
- Jul 21, 2012
- Messages
- 4,412
- Location
- Mid-Michigan
- Tractor
- NH T-1520 HST, NH TC33DA HST, Case DX26 HST, .Terramite T5C, . NH L785
We've built boxes as proposed for basements that may flood and to ease W/D access. Second the 3/4" ply top and 10"-12" center spacing as suits o'all dimension. Wood and paint, that's it. (Also built/carpeted a few for console TVs years ago to ease watching from a recliner.
'Box' may need some sound deadening (a few internal braces?) but don't expect rubber cushions to work much better than carpet would as far as stabilizing (during spin cycle, etc). Given room to jiggle a machine will do so (much more with top loaders) and try to 'walk' no matter how level or how confident that all loads will balance during spin.
Things might run more 'steadily' if W & D are mounted on the same platform. (Use a Forster bit to pocket their feet 1/8" into the top.) Weight of box and both appliances should help them stay put, with 'dampers' beneath the whole shebang. (BTDT, .. easy peasy) tog
btw: Stall mat on concrete may show dampness (hydrostatic pressure) from below grade. On a wood floor I'd expect some 'rumble' even with it. (A thinner mat'l may reduce 'rock-n-roll' vs something that's a bit 'springy'.)
