murphy1244
Super Star Member
- Joined
- Nov 25, 2011
- Messages
- 19,512
- Location
- Ohio
- Tractor
- Kubota 1120 RTV Kioti DK-40, MF-135, Ventrac 4500Y
Eric, what is the bolt pattern on the air seat?
Not the same, but found new a spring suspension seat base on eBay, turns out to be a Sears Seating brand: 607 / Compact Mechanical Suspension / 600 Series Seat Top - Sears Seating
Eric, I'm looking forward to your review of the v5400 after you get it installed. Do you have any specs on it other than the mounting layout? I'm trying to figure out how tall the top/front edge of the seat is (above the bottom of the base). I'd like to know the maximum and minimum heights (inflated/deflated). I see that Gravely Pro mowers use that seat, but I don't have any dealers close to my normal routines.
Great, thanks! I have seen some seat measurements with that center symbol, but what does "S.I.P." stand for?
I have the factory suspension seat upgrade on my Ferris and it looks just like the line drawing Eric posted. The seat is great and combined with the suspension on the mower makes for a great ride.
Looks like you're a bit a head of me in a search for a new seat. While you are looking for a flat seat, I'm actually needing one with lumbar support. Got long legs so maybe the MSG75 isn't the best choice for me? I gotta check, but I might have a different model of a Milsco in my skid steer. That unit only has the suspension in the seat pan to reduce the clearance requirements, but the lumbar profile is about right for me.
Edit- I have the Michigan 5300 in the skiddy. This seat looks like a splitting image of the Milsco 5400. Makes me think the two companies are related.
