another snow plow but on a mini loader
   / another snow plow but on a mini loader #1
farm boy00
Howard City, MI
John Deere M&MT, Case 1030 comfort king, Sears ST16, Craftsmen 6000, homemade articulation mini-loader
It's that time of the year. Snow plows. Just build one on my mini loader
Used all scrap around the place
Hauling the 3 garden tractor plows I had into the barn
Bucket taken off and set on a furnace pallet
Choose to use the old simpicity plow do to it having a A-frame.
Grinder got pinched cutting the lift arm off the plow
Got the frame set and clamped together. The colored angle is from old bed rails. Extra when we original cut the bed rails to make a truck tailgate
The loader arm will go right where the washers are
Frame made from uni-strut. Now just need add the supports
I'm thinking for some casters to use the wheels off the bed frame
Got they plow mounted and used it to level some dirt and some driveway work
Just got alot more done for welding done. Finally tried my turn at welding. Spent about 2hrs on the shop welding and grinding.
Had to redo the curl mounts. I tried to use the old mounts on the plow but couldn't get the curl needed for lifting the plow more then 1ft let alone stacking 5ft. So made it the traditional way
And used some bed angle for supports (baby blue ) and decided why not make some casters incase. Got one bolted on and other ready to. Just need to build a latch system. Any ideas? ?
Tell me about it. Had alot better luck when I got the welder fined tuned. I have learned alot from my watching my father so that's how I know to do alot of this
   / another snow plow but on a mini loader #7
What amp and wire speed are you running? It looks like your wire feed might be too fast for your amperage.
On our Lincoln it was running 16 amp and wire was around 275. I at one point kicked it up to 300 which helped some but then dropped it to 250 which worked best. I try not to adjust it much just cause its used alot for our sheet metal shop
   / another snow plow but on a mini loader #9
I am not familiar with the settings on your Lincoln. What does the door chart say? My charts says for 1/4 steel using .30 wire to run medium2 and wire speed 5.5. I find medium2 to be too cold and medium4 works better for 1/4 inch steel.
We actually just welded my big allis chalmers wd45 loader tonight. The previous tractor it was on had a tree fall on it and bent the loader. Well it turns out it wasn't my welding that caused problems. My father welded the allis loader and the wire had problems feeding. It would catch and then slip. Finally got better in the last few minutes of welding
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A59904)
2012 INTERNATIONAL...
Tafe 45DI (A53317)
Tafe 45DI (A53317)
2015 Kia Sorento AWD SUV (A56859)
2015 Kia Sorento...
2021 Ford F-150 XL (A53317)
2021 Ford F-150 XL...
207282 (A52708)
207282 (A52708)
2013 Land Rover Range Rover Sport 4X4 SUV (A55853)
2013 Land Rover...
