Anti Seize question.
   / Anti Seize question. #11
Just buy an anti seize that states it doesn't wash out. Black, silver, copper, lots of colors, pick your favorite.
   / Anti Seize question. #12
I have a 2007 Kubota B7800, the problem is my clutch release rod seized up in the aluminum bell housing. I would like to know what type of anti seize or other lubrication to use. I didn't realize there were quite a few different types of anti seize available. Copper, Silver, Zinc, Nickel. None specifically say steel and aluminum application. Unfortunately it is a one time lubrication, so I definitely want something that will at least last till the next clutch job. The tractor only had 160 hrs. and is garage kept.
buy a can of Chesterson Antisieze and it will last you the rest of your life. Best you can buy.
   / Anti Seize question. #13
I live in the rust belt (Northeast) repairing autos and I use plain ole grease on everything to keep (things) from seizing.
I know this works because I do this on my own vehicles that I keep until they rust away.
I like grease with Moly which is recommended for high pressure applications like bucket pins which makes it universal.
Most likely there was little or no grease applied when it was built.
I've found that if you keep air & water out corrosion cannot get started.
I use WD-40 to keep those pivots & bushings wet that cannot be greased.
Having said that any of the recommendations made here will work but anti seize is not a lubricant!
90cummins
   / Anti Seize question. #14
90cummins
Neither is WD40. It stands for Water Displacement formula # 40. Spray a bit into a cup & come back in a week. It will have evaporated leaving a yellow varnish behind. Many better penetrating oils out there (i like PB blaster) & many better lubes & protectants (Fluid-Film is highly recomended on TBN). WD40 is crap for what most people use it for. Boggles my mind its so popular.
   / Anti Seize question. #15
I use WD40 in the following ways. I use it as a cleaner to remove grease, tar and such. I use it as a water displacement for tools that have gotten wet, in a pinch I have used it for cutting fluid. It is OK to use to "unstick" something, but as you said, it is a Pixx Poor lubricant. I am a Fluid Film guy for a quick spray lube/coating. It works as stays put as a light grease. I use lots of other things too, but WD is more cleaner than lubricant.
   / Anti Seize question. #16
The only thing I use WD 40 for is a degreaser / cleaner.
   / Anti Seize question. #17
It's a better starting aid than ether, well at least you won't have washed-out cylinders when you finally do get it started.
WD-40 does have some lubricating ability, but it is not something one should count on.
I make my own "spray lube" by the quart for about 1/2 the cost of a can of commercial stuff, it is hard to find sprayers that last with it tho.
   / Anti Seize question. #18
   / Anti Seize question. #19
Using WD-40 as a lubricant, is the equivalent of using duct to "repair" something. :laughing:
   / Anti Seize question. #20
Um... I used Duct tape to repair a small hole in my back patio's sun canopy, and it has lasted for over a year... Any WD-40 lube job would not last that long.:)
2016 John Deere Gator 825i 4x4 Utility Cart (A53421)
2016 John Deere...
2019 Allmand Night-Lite V-Series 7kW S/A Towable Light Tower (A52377)
2019 Allmand...
2022 JOHN DEERE 331G LOT NUMBER 96 (A53084)
2022 JOHN DEERE...
2017 Freightliner M2 106 TMA Attenuator Truck (A52377)
2017 Freightliner...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A52377)
2021 Allmand Bros...
