Mesquite Removal with a root plow question (San Antonio, TX Area)
   / Mesquite Removal with a root plow question (San Antonio, TX Area) #1
bikenraider99
Marion, TX
Mahindra Max24
Evening folks. Decided to post this up after reading a lot and talking to some tractor folks here in Houston (I know, I know, not a lot of them but there are some :) ). I'm inheriting about 3 acres from my folks just outside of Seguin/San Antonio. My dilemma is Mesquite removal. I've been looking at a root plow to aide in the removal of about a dozen small trees on the land. I figured it was going to be a 3 part process: 1)Cutting down the tree to a short stump, 2) rolling over with a root plow, 3) hauling everything off site. I run a compact set up, Mahinda 24XL, which does what I need it to do on my city and suburban lots and brush hog my parents space. I've talked to my dealer about the root plow in question; and have been assured my little tractor can handle it (of course it can says the salesman *L* ). I've also read other threads where folks are using bigger tractors, grubbers, and insecticides; all of which have their pros and cons which leave something to be desired by me, and not much about the root plow. I'm wondering if my plan works or if I'm going to hit a snag (no pun intended). Does anyone have any experience with root plows? Any comments or opinions? Appreciate it folks.
   / Mesquite Removal with a root plow question (San Antonio, TX Area) #2
Welcome to TBN! I don't have any good advice for you on root plows but I'm sure someone will jump in here pretty soon!
Congrats on your place in Marion. Fine part of God's Country! There were bumper stickers I used to see around San Antonio that said, " Nothing to do in San Antonio. I'm going to Marion!"
   / Mesquite Removal with a root plow question (San Antonio, TX Area) #3
With 12 small trees and by small I'm thinking 2" diameter about 10 feet tall I think renting a backhoe for a day would be best. When I had 10 acres root plowed it was done by a dozer plowing 3' underground. You would need a very large tractor to be effective.
   / Mesquite Removal with a root plow question (San Antonio, TX Area) #4
There are root plows and ROOT PLOWS.
The large ones are my only experience.
What does yours look like?
Bruce
   / Mesquite Removal with a root plow question (San Antonio, TX Area) #5
I live back east but I have ti wonder if renting a small backhoe would be cheaper and more effective. Ed
   / Mesquite Removal with a root plow question (San Antonio, TX Area) #6
Bruce
Yep that is what mine looked like that I hired out. My land was black land not sand and he left the field with bolder size dirt clods. He then use a large disc on a 125hp tractor to smooth the land out. Before he root plowed he scraped all the tops off and put them in a burn pile. Even now the field requires yearly maintenance because 100's of mesquite pop up every year.
   / Mesquite Removal with a root plow question (San Antonio, TX Area) #7
I am with TXDON on this. I think you will be disappointed in what a root plow will do with your sized tractor with the mesquite. If the mesquite is too big for you to run over and mow down with your tractor, there is no way a root plow on it will cut the roots--you will either stall or just slide over.
I will either rent a back hoe or look for someone who "grubs" mesquite. That is what we did. I had a guy come out with his skid steer with a mesquite grubber. He did a great job on 5 ac.
   / Mesquite Removal with a root plow question (San Antonio, TX Area) #8
Yup, I'm from S. Texas and most likely a mesqu you can't mow down will laugh at your SCUT. Rent an Excavator.
   / Mesquite Removal with a root plow question (San Antonio, TX Area) #10
2018 Kubota SVL95-2s (A50120)
2018 Kubota...
2009 John Deere 2020A Progator (RUNS) (A50774)
2009 John Deere...
2015 International DuraStar 4300 Johnston VT651 Street Sweeper Truck (A50323)
2015 International...
27ft x 24ft Metal Building (A51573)
27ft x 24ft Metal...
2003 Ford E-350 16ft Box Truck (A50323)
2003 Ford E-350...
P.T Farm Wagon (A50121)
P.T Farm Wagon...
