Mesquite Removal with a root plow question (San Antonio, TX Area)
   / Mesquite Removal with a root plow question (San Antonio, TX Area) #21
I found that it is very important to spray stumps almost immediately after cutting to get a good kill.
Soak the entire stump paying attention to getting plenty of chemical around the bark edge.
Thanks, I think that is what I do wrong, I usually don't get the spray till several months later.
   / Mesquite Removal with a root plow question (San Antonio, TX Area) #22
Have you ever tried just painting full strength 2,4-D on the cut stumps?
   / Mesquite Removal with a root plow question (San Antonio, TX Area) #23
I've never tried 2,4,D. Have you? I've heard you have to be really careful about it getting into run off water.
   / Mesquite Removal with a root plow question (San Antonio, TX Area) #24
Remedy / Diesel at 25%\75% works well if applied to cut stump right after cutting.
Sent from my iPad using TractorByNet
   / Mesquite Removal with a root plow question (San Antonio, TX Area) #25
I use 2,4-D and dicamba quite a bit for broadleaf weed control. I don't think it's labeled for Mesquite though, and I would be doubtful about it's effectiveness since it really doesn't do much to non-broadleaf plants. That said, it does put the hurt on bramble (wild blackberry) bushes so if you catch the mesquite early enough, it might work.
I think I'd stick with the Remedy/diesel mix that's labeled for mesquite control though.
   / Mesquite Removal with a root plow question (San Antonio, TX Area) #26
The 2,4D is a lot cheaper than Remedy. It's killed everything I have applied it to. Never used it on mesquite is why I was asking if it works on it. I have killed chinese tallow with it, china berry, . Just paint it undiluted on the fresh cut stump.
   / Mesquite Removal with a root plow question (San Antonio, TX Area) #27
Chinese Tallow is a broad leaf, though. I wouldn't classify mesquite as a broad leaf.
2012 John Deere 7280R MFWD Tractor (A52748)
2012 John Deere...
2006 KENWORTH T800 TANDEM SLEEPER TRUCK (A52141)
2006 KENWORTH T800...
Rhino MD-84 (A50121)
2013 VOLVO VNM TANDEM AXLE DAY CAB (A52141)
2013 VOLVO VNM...
2012 MCLAUGLIN/VERMEER V800AWXT VACUUM EXCAVATOR (A52141)
2012...
International 56 2-Row Pull Cornplanter (A50774)
International 56...
