Looking for a decent generator.. 5000 watts
/ Looking for a decent generator.. 5000 watts #21
A garage door opener doesn't pull that much power. They usually are rated at 1/2 - 3/4 hp.
I agree. Probably a 3000 watt generator will do him,. But using a small ups to clean the power should be part of his solution
/ Looking for a decent generator.. 5000 watts #22
Seriously, garage door openers can be released to work manually. Just pull the cord to release it from the drive track. Refrigerators, lights and a few tools don't use much.
As to sensitive electronics, get a UPS like this for less than $60.
Then clean power won't be so critical and you can get a cheaper and smaller portable generator.
Is that big enough to use when my freezer and refrigerator start up?
Honda say 2,400 watts for them to start up.
Honda Generators - Wattage calculator
I had a friend fry the electronics on his high end refrigerator with a generator and it was like a $1,000 repair.
And it's getting so many things have "sensitive" electronics in them.
A typical 1500 VA UPS costs over $150.
The 3.5KW generator I posted from Costco is only $350.
/ Looking for a decent generator.. 5000 watts #23
Is there a clear common problem that causes these high end refrigerators to go belly up when run by a generator? Too little voltage?? Too much?? Frequency off??? Surge???
/ Looking for a decent generator.. 5000 watts #24
Well even though the OP has not returned I thought I'd throw this into the thread -
Costco has the on sale for $350.
Big point about this one is that it's good for sensitive electronics.
Champion 3500wt Running / 4375wt Peak Portable Generator, 5% THD, CARB & EPA Certified
doesn't do 240V
Newbury, thanks for the tip, I didn't know Champion even made such a thing! I just finished ordering one because I've heard horror stories about people burning out the mainboard on their pellet stoves with a conventional generator.
Oddly enough, I couldn't find that particular generator on Champion's website
Now I guess I need to put out a Craiglist ad to sell my old Champion generator
/ Looking for a decent generator.. 5000 watts #25
It's not the voltage or frequency, It's the type of sine wave the generator puts out. Lower cost generators put out a square sine wave, better ones may put out a modified sine wave, but sensitive electronics (computers, LED TVs, etc need a pure sine wave.
This even extends to inverters, most of them don't put out pure sine wave current.
/ Looking for a decent generator.. 5000 watts #26
If you keep your eye out there are good used generators on the market through CL. I picked up a 6000watt liquid cooled Honda that makes no more noise than an idling Accord when someone upgraded to a permanent automatic LP generator. Also, many people sell generators because they need the carburetor cleaned which takes about half an hour. If you need something right away and are on a budget, the HF Predator generators are good deals. Not necessarily the very best or quietest generators on the planet but the price is hard to beat (and they do work fine). Subaru/Robin engines are great too. I'd personally stay clear of the high priced Yamaha/Honda inverter generators unless you are using it for an RV or camp.
+1 on that. For the cost of a Honda portable inverter of any capacity, you can get a Generac standby unit. I own a Yamaha 2800I myself and it was 1500 bucks but my prime use is an RV. I own a Generac 17KW for the house. Much more convenient to use.
/ Looking for a decent generator.. 5000 watts #27
The Yamaha does..... In fact, in the begining, Yamaha supplied the generator heads to Honda for their inverter units.
/ Looking for a decent generator.. 5000 watts #28
This is one of those cases where you kind of get what you pay for. The Honda Gens and my guess is the Yamaha's output a pretty clean sine wave form. I don't know of any cheap gens that do. If I did buy a cheap gen I would test it first I power way too many electronics and don't want to think about it.
/ Looking for a decent generator.. 5000 watts #30
It,s hard to beat a honda generator as far as quietness and quality.
/ Looking for a decent generator.. 5000 watts #31
Not really cheaper for the two about the same I think ($2000) but you do get some more wattage. The 3000 is quieter than a 2000 and you have one machine vs. two to maintain... the two reasons I went with the 3000. One advantage going the 2 by 2K route is you can grab one of them and take with you much easier (weight) than a 3000.
I have owned both the honda 3000 and the honda 2000 IMHO the 2000 was quieter.
/ Looking for a decent generator.. 5000 watts #32
I've owned neither. I bought my Yamaha 2800I about 12 years ago and it runs like a top (just remember to add Stabil Marine formula to the crap e-gas) is all it takes.
According to what I've read (may be false, not sure but) from what I've read the Yamaha 2800I commercial unit I have (not the fully enclosed genny but the one in the cradle) is quieter than a comparable Honda. I have to say, it's extremely quiet. I can have it running outside the RV and I cannot hear it inside.
Always starts first pull and it's an easy pull with the auto compression release.
I see they haven't got any cheaper. $1500 is about average.
/ Looking for a decent generator.. 5000 watts #33
When you actually need a generator and are in the heat of the battle, you would pay or do anything to get one that works. So my free advice is to buy a Honda from the get-go. It's the only generator that consistently gets perfect reviews. All of the others have some sort of a problem but not the Honda. It will work when it's supposed to. When the water is rising and 1/2" from spilling over, the price difference won't matter.
/ Looking for a decent generator.. 5000 watts #34
Whatever brand you prefer, look at the end of the generator opposite the engine. If the end cap is attached with 4 bolts around the outside, it has USA made electronics. If the end cap is held on with 2 bolts near the middle, it has China made electronics.
/ Looking for a decent generator.. 5000 watts #35
Actually I think Champion only makes that for Costco. During my "looking it up" I ran across an internet post saying that Costco has Champion put in a better alternator.
you don't need those features, because this is a < 5% THD generator, this is a MUCH better unit than the DuroMax deal at Ebay right now for $20 less. I have the larger 7000 watt version of this and looked at the output on an oscilloscope - it's actually a nice, relatively clean sine wave, unlike the rest of the ChinaGenerators. Costco has different alternators put on the units sold in their stores, so a model that is sold on Amazon and Costco may appear to be otherwise identical, but the Costco version is spec'd at < 5% THD and produces much cleaner power.
Champion gas "Clean Sine" < 5% THD 3500 running /4375 peak watt generator for $350 shipped at Costco - Slickdeals.net
/ Looking for a decent generator.. 5000 watts #36
I read in a magazine (don't remember what one) a shoot out between all the smaller "inverter" gen sets...
The Honda 2000 beat out all the others in having the "cleanest" sine wave, with the cheapo ones the worst...
BTW, Yamaha came in second...
SR
/ Looking for a decent generator.. 5000 watts #37
SR
Do you remember if they tested the Costco version of Champion?
/ Looking for a decent generator.. 5000 watts #38
Are you talking about the EU3000iS with ecothrottle on? I believe you but specs say otherwise I think. I love my 3000iS!
/ Looking for a decent generator.. 5000 watts #39
SR
I've run everything from my RV microwave to my laptop on the Yamaha with no issue so while it might have come in second behind the Honda, no issue with me. On Generator's to go website the Yamaha gets 5 stars (what ever thats worth)..... Definitely 5 stars with me. Like I stated before, 12 plus years and no issues and thats a lot of use. I don't have an hour meter on it but I imagine over 1000 hours. I use it in the summer for the RV and in the winter hunting/camping with the RV plus around the farm for remote power for skilsaws and electric drills.
I change the oil twice yearly and it gets a new sparkplug about every 2 years. I've cleaned the USDA spark arrestor 2 times and adjusted the valves once. It has the 12 volt battery charge but I've never used that. Runs over 9 hours on economy throttle (load sensing) and regular throttle is about 7.5 hours a tank.
I'd buy another one in a heartbeat but I'd say this one will outlast me....
/ Looking for a decent generator.. 5000 watts #40
No argument... Yamaha's aren't cheap either. I will say it again... you generally get what you pay for.
2015 BMW 328i Sedan (A59231)
2015 BMW 328i...
2021 BOBCAT T870 SKID STEER (A60429)
2021 BOBCAT T870...
Redirective Crash Cushion Guardrail (A59230)
Redirective Crash...
2015 Toro Sand Pro 5040 Bunker Rake (A59228)
2015 Toro Sand Pro...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A57454)
New/Unused AGT...
2020 VOLVO 760 TANDEM AXLE SLEEPER (A57880)
2020 VOLVO 760...
