Good morning!!!!
   / Good morning!!!! #41,311
Don, Our internet tower makes our home look like a command station. They had to raise the telescoping tower to 45' IIRC. Did you go with the "Z" company or the "LW" company? I know the "LW" company is at full capacity and now has trouble at peak periods keeping everyone's speed where it is supposed to be.
Did you get your new cart from the Austin dealer? How many batteries does it have? We have a project at work where they bought some specialized batteries, car sized, lithium based, that cost $1100 each. They are light weight and I'd bet they'd make decent cart batteries but, Yeeouch!
Good afternoon. 50˚clear skies now, was 28˚ at sunrise.
Kyle, we went with Z. The speed is variable from 1Mbps to 11Mbps but mostly 3Mbps. If any of you can please try this At&T speed test:
AT&T High Speed Internet Speed Test
and let me know your speed. I wonder how this rural service compares to others.
Kyle, I got the Cart from Liberty Hills and it has 6 Trojan batteries.
The cold North wind was blowing hard yesterday as I was feeding Dad's cows with his non-cabbed tractor, this may be his last year in the cattle business.
   / Good morning!!!! #41,312
Good afternoon. 50˚clear skies now, was 28˚ at sunrise. Kyle, we went with Z. The speed is variable from 1Mbps to 11Mbps but mostly 3Mbps. If any of you can please try this At&T speed test: AT&T High Speed Internet Speed Test and let me know your speed. I wonder how this rural service compares to others. Kyle, I got the Cart from Liberty Hills and it has 6 Trojan batteries. The cold North wind was blowing hard yesterday as I was feeding Dad's cows with his non-cabbed tractor, this may be his last year in the cattle business.
Don;
I have speed test app on my iPad and getting 20.43 Mbps download and 4.92 Mbps upload on Excede satellite internet.
Sent from my iPad using TractorByNet
   / Good morning!!!! #41,313
Moved a lot of sand and ABC today, very glad my helper showed up...the calvary. I had most of the ABC leveled in the barn floor, left him to finish it and then put a layer of sand on top of that. Then using up a big pile of old pavers. Mud, mud mud, tired of getting the Gravely stuck. Maybe ought to consider getting some R1 tires; the hybrids are fine for everything but mud as they are almost useless once they plug up. What a mess this project has made of my fields...but at least it wasn't the lawn...
Decided to do a simple culvert instead of a bridge over that water diversion ditch. Thinking a 12 inch pipe should be fine, just surface water.
Hard pipe? My helper says use the cheap corrugated stuff and dump a load of sand on it, then ABC. Wouldn't solid pipe be better? Only a ten foot section or so.
   / Good morning!!!! #41,314
I got 28.11 down and 6.1 up and that's from a long way away. (almost 8k miles)
   / Good morning!!!! #41,315
Was in 60s, now 50s,
Was sunny, then sunny with a downpour, then high winds, then everything.
   / Good morning!!!! #41,317
We use AT&T Hotspot mifi and I got 9.59 down and 1.01 up. How is your Dad? Is he home yet?
Farmer, Yes I did, thank you, I haven't gotten a chance to check it yet. The dog was the friends that I went with. Although I guess I own part interest in it. I loaned him some money to get it. LOL
Drew, sounds like you are getting lots done. I vote for the bridge, but then I would want you to get fancy and put up a covered bridge. If you aren't going for that then just put in a culvert.
   / Good morning!!!! #41,318
29.67 Mbps download, 6.12 Mbps upload - this is with Comcast.
   / Good morning!!!! #41,319
28 down, 8 up with the AT&T test, 43 down, 8 up with Speedtest.net using Suddenlink cable
quite a difference
and I should be running between 45 and 50 down so things are slowish, relatively
   / Good morning!!!! #41,320
Drew not to mind your business but galvanized pipe has a shelf life of 20 years double walled plastic smooth inside. Basically same price just a better product in my mind
2016 Ram 4500 Crew Cab Landscape Dump Truck (A56858)
2016 Ram 4500 Crew...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2016 Troy-Bilt 18in. Push Mower (A55973)
2016 Troy-Bilt...
25 TANDEM DUAL GOOSENECK TRAILER (A58214)
25 TANDEM DUAL...
2007 Chrysler Aspen SUV (A56859)
2007 Chrysler...
2020 CATERPILLAR 299D3 SKID STEER (A52709)
2020 CATERPILLAR...
