I'm building a wood shed....I need some help
   / I'm building a wood shed....I need some help #141
I use a electric shears because it won't leave a burr like the other methods. The above post must have been a typo because a diamond blade won't cut metal. If you go the circular saw route, just buy a 7-1/4" thin kerf abrasive blade. It'll zip right through the metal.
   / I'm building a wood shed....I need some help #142
For those recommending the abrasive blades, be advised that the roofing/siding suppliers specifically say not to use abrasive blades and that it will void the warranty. They may work just fine, but I went with the metal cutting blade because after spending several thousand $ on metal, I figured I should follow the recommendations.
   / I'm building a wood shed....I need some help #143
No typo, do it all the time. Not the smooth continuous rim blades, the one with ridges(?) like this Shop Skil 7-in Wet or Dry Turbo Diamond Circular Saw Blade at Lowes.com Less cost as a carbide, but slightly quieter, and a lot less metal shards flying at you. I don't use the skil brand, or any of the ones lowe's has, I usually get mine at the local ace. Cost more, but I think they're better quality. I've stacked up to 5 thick and cut em to length.
2008 KOMATSU PC200LC-8 EXCAVATOR (A52706)
2008 KOMATSU...
2015 Jeep Compass Latitude SUV (A55758)
2015 Jeep Compass...
2023 54' Hooklift Dumpster 20 Cubic Yard (A55788)
2023 54' Hooklift...
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATES (A54757)
UNUSED LANDHONOR...
2014 CATERPILLAR 299D SKID STEER (A52705)
2014 CATERPILLAR...
