Mesquite Removal with a root plow question (San Antonio, TX Area)
   / Mesquite Removal with a root plow question (San Antonio, TX Area) #21
I found that it is very important to spray stumps almost immediately after cutting to get a good kill.
Soak the entire stump paying attention to getting plenty of chemical around the bark edge.
Thanks, I think that is what I do wrong, I usually don't get the spray till several months later.
   / Mesquite Removal with a root plow question (San Antonio, TX Area) #22
Have you ever tried just painting full strength 2,4-D on the cut stumps?
   / Mesquite Removal with a root plow question (San Antonio, TX Area) #23
I've never tried 2,4,D. Have you? I've heard you have to be really careful about it getting into run off water.
   / Mesquite Removal with a root plow question (San Antonio, TX Area) #24
Remedy / Diesel at 25%\75% works well if applied to cut stump right after cutting.
Sent from my iPad using TractorByNet
   / Mesquite Removal with a root plow question (San Antonio, TX Area) #25
I use 2,4-D and dicamba quite a bit for broadleaf weed control. I don't think it's labeled for Mesquite though, and I would be doubtful about it's effectiveness since it really doesn't do much to non-broadleaf plants. That said, it does put the hurt on bramble (wild blackberry) bushes so if you catch the mesquite early enough, it might work.
I think I'd stick with the Remedy/diesel mix that's labeled for mesquite control though.
   / Mesquite Removal with a root plow question (San Antonio, TX Area) #26
The 2,4D is a lot cheaper than Remedy. It's killed everything I have applied it to. Never used it on mesquite is why I was asking if it works on it. I have killed chinese tallow with it, china berry, . Just paint it undiluted on the fresh cut stump.
   / Mesquite Removal with a root plow question (San Antonio, TX Area) #27
Chinese Tallow is a broad leaf, though. I wouldn't classify mesquite as a broad leaf.
Alloway 1315 10"x61' Transport Auger (A50774)
Alloway 1315...
2016 Kenworth T880 T/A Vactor 2112P-16 Combination Sewer Jetter Vacuum Truck (A50323)
2016 Kenworth T880...
2017 Ford F-550 Ext. Cab Valve Maintenance Vacuum Service Truck (A50323)
2017 Ford F-550...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
2007 Kubota M5040D 50HP 4WD Front Loader Utility Tractor (A50322)
2007 Kubota M5040D...
2011 Ford Transit Connect Cargo Van (A50323)
2011 Ford Transit...
