Looking for a decent generator.. 5000 watts
   / Looking for a decent generator.. 5000 watts #91
If Generac told him "all of their generators are between 3-6 %", you both could be right. Maybe their worst ones are in the 5-6% range, and all their XP and Inverter models are less than 5% (3-4%).
I called and verified. The GP line which is their most popular gen is 10% or higher. Like I said earlier the only portable model with an acceptable Thd for electronic devices or thd sensitive electrical components are the Xp and inpverter lines. All of their home standby units are less than 5%.
   / Looking for a decent generator.. 5000 watts #92
Thanks for following up.
   / Looking for a decent generator.. 5000 watts #93
Any easy way to measure the THD?
   / Looking for a decent generator.. 5000 watts #95
   / Looking for a decent generator.. 5000 watts #96
Well just looking for a device I ran across this:
Power requirements for
furnaces
Furnaces, unlike consumer electronics,
do not have a built-in
regulated power supply (which
would add about $1500 to the
cost). They rely on a clean, consistent
sine wave to power an
IFC (integrated furnace control)
and establish clock timing and
synchronization of integrated
circuits.
A simple IFC may only
control furnace functions such
as turning line or low voltage
switches on and off, controlling
fan-timing circuits, and monitoring
flame rectification circuits.
More advanced IFCs also control
voltage to igniters, ECM and VFD
motors, and variable frequency
drives.
Even the simplest IFC may not
operate when supplied with poor
quality power.
Furnaces have a minimum
basic electrical requirement for
voltage, frequency and power
quality. The accepted standard
is:
120 V ア 10 % (108 V to
132 V)
60 Hz frequency ア 3 % (57 Hz
to 63 Hz)
Harmonic distortion <5 % THD
Furnaces supplied with voltages
that have harmonic distortion
greater than 8 % THD may not
operate or will operate with
possible damaging consequences
for the electronic circuitry and components.
from http://support.fluke.com/find-sales/Download/Asset/3497420_6112_ENG_A_W.PDF
Think I might need cleaner power for my $3,000 furnace.
   / Looking for a decent generator.. 5000 watts #97
Ok,, I had a chance to call back today.. This time the person put me on hold for quite some time.. Said they were trying to contact a generator tech.. After a while on hold, the person tells me, that don't have that info available for my generator model. I have no idea why they wouldn't have that info available to them.. My generator is probably 8 -10 yrs old
The problems I have read about the new / inverter generators, is with the GFCI breakers tripping when connected to the house.. To prevent this.. the jumper wire from the neutral and ground within the generator wiring would need to be removed..
it is said some generator manufactures will instruct you how ,and where to find this jumper wire, while others won't
   / Looking for a decent generator.. 5000 watts #98
What model do you have?
TANK MANIFOLD (A58214)
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
2008 DOOSAN G25 GENERATOR (A55745)
2008 DOOSAN G25...
2024 CATERPILLAR 255 SKID STEER (A60429)
2024 CATERPILLAR...
2008 New Holland T2420 (A60462)
2008 New Holland...
294 (A52706)
294 (A52706)
