Canned Gasoline?
   / Canned Gasoline? #51
I've bought some canned "fuel", I haven't bought ANY canned gas... SR
And what is the difference in that and ethanol free gas? Can I put diesel in a bottle and call it canned fuel?
   / Canned Gasoline? #52
Bunch or years ago (more than I like to admit) we were celebrating my 21st and we dreamed of 'get rich schemes' all while celebrating.
I recall suggesting 'instant water' and we all laughed at my crazy idea.
Well just look at bottle water sales, is that not instant water? (and often simply out of a tap, but in a bottle @ $1.00 or more)
Marketing!
   / Canned Gasoline? #53
I bet that you ALSO believe that they take "dino" oil, put it in can and call it "synthetic" too!
SR
   / Canned Gasoline? #57
So there's no gasoline in those cans, right?
It's engineered (synthetic) fuel...
That's why it has such a long shelf life...
Those that keep "claiming" that it's non E gas or that it's the "same thing" as non E gas are wrong, that's NOT what it is.
NOW, if you read ALL of my post here on this subject, you will see that I don't use it all the time. I bought it "for a purpose" and really, I don't have a dog in this fight. BUT, it's fit's my purpose "perfectly" and there is a place for it on todays market...
SR
   / Canned Gasoline? #58
My can of canned gas clams nothing about it being synthetic engineered fuel. It does however use synthetic oil. It claims it has a shelf life of 2 years. It uses echo red armor oil with a fuel stabilizer. You can buy echo red armor oil by the case to mix your own gas. The red armor oil claims it also makes gas last 2 years. The only advantage of the canned gas that I see is 93 octane. Please explain what the difference is. image-3433655678.jpg image-3763477184.jpg
   / Canned Gasoline? #59
My can of canned gas clams nothing about it being synthetic engineered fuel. It does however use synthetic oil. It claims it has a shelf life of 2 years. It uses echo red armor oil with a fuel stabilizer. You can buy echo red armor oil by the case to mix your own gas. The red armor oil claims it also makes gas last 2 years. The only advantage of the canned gas that I see is 93 octane. Please explain what the difference is. View attachment 454472 View attachment 454473
From the Echo website...
ECHO PowerFuel is a pre-mixed fuel, containing 93 octane gas and oil, that’s ready-to-use right out of the can – there is no need to measure or mix oil. It contains no ethanol and is specifically developed at a 50:1 ratio and is the only pre-mixed fuel that uses ECHO Red Armor Oil™. ECHO PowerFuel is recommended for use in all air-cooled, 2-stroke engines. It facilitates proper break-in and helps extend the life of your equipment. With ECHO PowerFuel you never have to worry about stale fuel – in fact, it stays stable and usable for up to 2 years after opening! ECHO PowerFuel even makes winter storage and maintenance easier – it is not necessary to drain the tank unless it has remained in the tank for over 2 years.
   / Canned Gasoline? #60
The red armor oil also claims to make regular ethanol free fuel stable for two years.
2016 FREIGHTLINER CASCADIA TANDEM AXLE 6X4 MID ROOF SLEEPER TRUCK (A51219)
2016 FREIGHTLINER...
2022 BANDIT 2550TK STUMP GRINDER (A51242)
2022 BANDIT 2550TK...
2020 CASE CX37C EXCAVATOR (A51242)
2020 CASE CX37C...
71058 (A49346)
71058 (A49346)
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
CATERPILLAR 325FL CR EXCAVATOR (A51242)
CATERPILLAR 325FL...
