Canned Gasoline?
   / Canned Gasoline? #51
I've bought some canned "fuel", I haven't bought ANY canned gas... SR
And what is the difference in that and ethanol free gas? Can I put diesel in a bottle and call it canned fuel?
   / Canned Gasoline? #52
Bunch or years ago (more than I like to admit) we were celebrating my 21st and we dreamed of 'get rich schemes' all while celebrating.
I recall suggesting 'instant water' and we all laughed at my crazy idea.
Well just look at bottle water sales, is that not instant water? (and often simply out of a tap, but in a bottle @ $1.00 or more)
Marketing!
   / Canned Gasoline? #53
I bet that you ALSO believe that they take "dino" oil, put it in can and call it "synthetic" too!
SR
   / Canned Gasoline? #57
So there's no gasoline in those cans, right?
It's engineered (synthetic) fuel...
That's why it has such a long shelf life...
Those that keep "claiming" that it's non E gas or that it's the "same thing" as non E gas are wrong, that's NOT what it is.
NOW, if you read ALL of my post here on this subject, you will see that I don't use it all the time. I bought it "for a purpose" and really, I don't have a dog in this fight. BUT, it's fit's my purpose "perfectly" and there is a place for it on todays market...
SR
   / Canned Gasoline? #58
My can of canned gas clams nothing about it being synthetic engineered fuel. It does however use synthetic oil. It claims it has a shelf life of 2 years. It uses echo red armor oil with a fuel stabilizer. You can buy echo red armor oil by the case to mix your own gas. The red armor oil claims it also makes gas last 2 years. The only advantage of the canned gas that I see is 93 octane. Please explain what the difference is. image-3433655678.jpg image-3763477184.jpg
   / Canned Gasoline? #59
My can of canned gas clams nothing about it being synthetic engineered fuel. It does however use synthetic oil. It claims it has a shelf life of 2 years. It uses echo red armor oil with a fuel stabilizer. You can buy echo red armor oil by the case to mix your own gas. The red armor oil claims it also makes gas last 2 years. The only advantage of the canned gas that I see is 93 octane. Please explain what the difference is. View attachment 454472 View attachment 454473
From the Echo website...
ECHO PowerFuel is a pre-mixed fuel, containing 93 octane gas and oil, that’s ready-to-use right out of the can – there is no need to measure or mix oil. It contains no ethanol and is specifically developed at a 50:1 ratio and is the only pre-mixed fuel that uses ECHO Red Armor Oil™. ECHO PowerFuel is recommended for use in all air-cooled, 2-stroke engines. It facilitates proper break-in and helps extend the life of your equipment. With ECHO PowerFuel you never have to worry about stale fuel – in fact, it stays stable and usable for up to 2 years after opening! ECHO PowerFuel even makes winter storage and maintenance easier – it is not necessary to drain the tank unless it has remained in the tank for over 2 years.
   / Canned Gasoline? #60
The red armor oil also claims to make regular ethanol free fuel stable for two years.
2018 GENIE GTH636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH636...
2019 FORD F-150 (A50854)
2019 FORD F-150...
2011 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2011 Ford F-150...
Roose Hog Cart (A50515)
Roose Hog Cart...
2019 BOBCAT S770 SKID STEER (A51242)
2019 BOBCAT S770...
2012 VOLVO DBL SLEEPER ROAD TRACTOR (A51243)
2012 VOLVO DBL...
