Canned Gasoline?
   / Canned Gasoline? #61
I run my chainsaws dry for winter storage and have no other need for 2 cycle fuel.
Have a can of Stihl MotoMix on the shelf for emergency situations like a tree falling across the driveway.
Seems like a prudent expenditure!
   / Canned Gasoline? #62
My can of canned gas clams nothing about it being synthetic engineered fuel. It does however use synthetic oil. It claims it has a shelf life of 2 years. It uses echo red armor oil with a fuel stabilizer. You can buy echo red armor oil by the case to mix your own gas. The red armor oil claims it also makes gas last 2 years. The only advantage of the canned gas that I see is 93 octane. Please explain what the difference is.
The difference is: you bought something different than what I buy...
What I buy is 95 octane with a 5 year shelf life...
NOW, I suppose you will try to tell me that it's all made the same, and.....................
SR
   / Canned Gasoline? #63
I keep the same 1.5 gallon of 50:1 that I mix myself all year round. It gets rotated out several times a year through regular use as my chainsaws and weed eater all use 50:1.
   / Canned Gasoline? #64
I assume you use trufuel. It is rated for 5 years unopened or two years after opening. The Echo canned gas carries the same 5 year unopened or 2 year opened claim. After you pour it in your chainsaw it and regular E free gas using the echo red armor have the same advertised shelf life. The trufuel says it uses synthetic lubricants, but nothing about using a synthetic fuel. My 72 cc saw and 65 cc blower get pretty thirsty and could drink a $84 5 gallon jug pretty quick.
   / Canned Gasoline? #65
NOPE!
Welllll, not as much. :laughing: we dumped directv after 17 years. Swamp logging ice road gun shop busters was getting old.
i watched all those shows and love them all. Pickers and pawn stars i have a ton of on the DVR so many good shows i have put them on the side. Pickers i am like 7 months+ behind. pawn stars i am like a year behind and sadly may never satch up!!!
I watch 80% of the man shows i think
   / Canned Gasoline? #66
plus 40:1 is the absolute minimum i want to run my stuff with oil wise. i like 32:1 to make sure everything is oiled well. Those long cuts in big wood put a strain on a saw as does running one in 90+degree heat just like a weedeater. 32:1 will not coak or carbon up, does not foul your plug or give you negative effects. That is if your tuned right. You have to retune to run it optimal. Some big saws have shown a HP improvement in cut times from 32:1 to 40:1 they may have put them on the dyno on AS i cant remember now. But the difference was not real world noticeable.
And like i said 92/3 octane is a selling point in 2 stroke fuel. yes the stihl owners manual says 89 but i think that is to compensate for people running stale fuel. ANd if you get ethonol fuel the higher octane allows it to still be ok once you soak up water lowering the octane in the fuel. Any two stoke will run fine in a two stroke at 87 octane. How can it detonate when the motor is running at 15,000 rpms and every power stroke it fires? everytime the fuel is in the cylinder it fires, and there is unburnt fuel in the exhaust. Thats what all this epa stuff tries to stop is the amount of fuel that is spent. They are putting strato carbs on them or cats in the mufflers to get rid of it or make the muffler so constrictive and hot that the fuel burns off in there. this is whats killing your modern saws is those hot temperatures. Getting rid of that stuff and letting them breathe easier with all the fuel that they want with plenty of oil to make a just wet exhaust is what you want. If your not getting oil out the exhaust then the exhaust side of your piston is not as oiled either and thats the side that scratches first.
   / Canned Gasoline? #67
Why would you run 32:1 in a high performance saw made to run 50:1?
   / Canned Gasoline? #68
Because someone once scored a cylinder at 50:1, so they thought more oil is better. Not saying that isn't true, but that's usually the case.
   / Canned Gasoline? #69
My small engine guy runs premium at 40 to 1 and said it keeps his landscapers coming back because they avoid/delay costly repairs.
Some of my old equipment is 16 to 1...
   / Canned Gasoline? #70
Although I did get three cans of 50:1 Husky gas with my new Husquvarna backpack blower, it will live on 40:1 mix once the store bought gas mix is used up. I run everything on 40:1, adjusting the carbs if necessary. Even my old 70's Craftsman 16:1 runs just fine on the new syn oil mixed at 40:1. The reason for 50:1 is not cuz' it is better for your motors, it's an emissions thing. All my 2 strokes work just fine on the 40:1... 16:1 was used before the new syn oils came out..
2016 Ford Fusion SE (A50324)
2016 Ford Fusion...
2021 Dodge Durango SUV (A50324)
2021 Dodge Durango...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2017 Ford F-150...
2008 BMW 528i Sedan (A50324)
2008 BMW 528i...
2025 LandHonor LHR-RC9200 9200lbs Ratchet Binders and G70 Chains (A49462)
2025 LandHonor...
