Belt sander or disc sander - or both?
   / Belt sander or disc sander - or both? #21
I could get by with the 12" at home but if you have a shop or business, get a 16" or 18". Remember, with the 12", you only have about 6" above the table and with bigger pieces you will need the room.
   / Belt sander or disc sander - or both? #22
Jim - I use a wire wheel attachment on s grinder for cleaning off rust, a flappy disc attachment for grinding off weld beads for a smooth finish and a pneumatic die grinder for grinding off my bad slag inclusion welds in tight corners.
John
   / Belt sander or disc sander - or both? #23
Like JbW, I also have a flap wheel in a 4.5" angle grinder, a cut-off wheel in another, a 60 grit stone in another yet, and a wire cup for removing rust in one more. I have a 8" stationary grinder I mainly only use for tungstens, and another 8" which has a weaker motor (northern tools brand) that has a flap disk on it and a buffing wheel on the other side.
I also have a die grinder, but I don't use it for post weld work unless I have porosity I can't get out of a tight spot or a bead gets in the way of another pieces fitup. The die grinder is really handy for making oval holes when you're putting tube through at an angle.
   / Belt sander or disc sander - or both? #24
+1 on the Harbor Freight 12" disc sander. I bought mine about 3-4 years ago and use it for wood only. Waiting for another good sale to get one for metal work.
12" Benchtop Disc Sander
Like others, I think a heavier iron table would be a plus when doing metal work.
   / Belt sander or disc sander - or both? #25
I have a combo disc/belt and rarely use it for metal. I have a bunch of cheap HF hand disc grinders with different wheels and find those most handy most of the time. I would like a large 12in or larger disc with enough power not to bog down though. The older I get the less I want to deal with combo machines. Always seem to be a compromise.
   / Belt sander or disc sander - or both? #26
I have a 2 x 72 belt grinder that has a flat place to grind, a slack place for a more rounded shape and a small wheel attachment that can cope pipe ect very easily. Works fast and is designed for metal. Ed
UNUSED 48 in. Heavy-Duty Bolt Cutters (A53117)
UNUSED 48 in...
VENTRY FAN / BRUSH BURNING SKID (A55745)
VENTRY FAN / BRUSH...
2016 E-Z Beever M12R Towable Brush Chipper (A50322)
2016 E-Z Beever...
2013 3400QB SUNDANCE 5TH WHEEL CAMPER (A52472)
2013 3400QB...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
