Belt sander or disc sander - or both?
   / Belt sander or disc sander - or both? #21
I could get by with the 12" at home but if you have a shop or business, get a 16" or 18". Remember, with the 12", you only have about 6" above the table and with bigger pieces you will need the room.
   / Belt sander or disc sander - or both? #22
Jim - I use a wire wheel attachment on s grinder for cleaning off rust, a flappy disc attachment for grinding off weld beads for a smooth finish and a pneumatic die grinder for grinding off my bad slag inclusion welds in tight corners.
John
   / Belt sander or disc sander - or both? #23
Like JbW, I also have a flap wheel in a 4.5" angle grinder, a cut-off wheel in another, a 60 grit stone in another yet, and a wire cup for removing rust in one more. I have a 8" stationary grinder I mainly only use for tungstens, and another 8" which has a weaker motor (northern tools brand) that has a flap disk on it and a buffing wheel on the other side.
I also have a die grinder, but I don't use it for post weld work unless I have porosity I can't get out of a tight spot or a bead gets in the way of another pieces fitup. The die grinder is really handy for making oval holes when you're putting tube through at an angle.
   / Belt sander or disc sander - or both? #24
+1 on the Harbor Freight 12" disc sander. I bought mine about 3-4 years ago and use it for wood only. Waiting for another good sale to get one for metal work.
12" Benchtop Disc Sander
Like others, I think a heavier iron table would be a plus when doing metal work.
   / Belt sander or disc sander - or both? #25
I have a combo disc/belt and rarely use it for metal. I have a bunch of cheap HF hand disc grinders with different wheels and find those most handy most of the time. I would like a large 12in or larger disc with enough power not to bog down though. The older I get the less I want to deal with combo machines. Always seem to be a compromise.
   / Belt sander or disc sander - or both? #26
I have a 2 x 72 belt grinder that has a flat place to grind, a slack place for a more rounded shape and a small wheel attachment that can cope pipe ect very easily. Works fast and is designed for metal. Ed
UNUSED 20PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 20PCS...
2023 John Deere 6155M Tractor (A53485)
2023 John Deere...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A53421)
2025 Kivel Forks...
2005 Kaufman Trailers Car Hauler Trailer (A55787)
2005 Kaufman...
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
More info coming soon! (A55787)
More info coming...
