BX25 vs XJ2025: ground clearance
   / BX25 vs XJ2025: ground clearance #1
Bothell, WA
BX25D-1
I was all set to buy an XJ2025 and then I noticed how far under the backhoe frame hung under the tractor. This looks like it totally negates any ground clearance the XJ2025 has. In fact it looks more likely to get high centered in rough terrain than the BX25.
   / BX25 vs XJ2025: ground clearance #2
The BX is a bit smaller machine than the LS. Looks to me a more direct comparison would be a B2601 as far as the size of the tractor. If you compare a backhoe setup on that model, you'll see a similar difference between the LS and the Kubota setup.
http://www.kubota.com/assets/product/B2301/photo/B2601_Loader_Transport.jpg
Many owners are quite happy with their LS machines, and they represent great value. Many other owners believe there is enough additional product content to justify their Kubota purchase, probably at a higher price point. The engineering to tightly integrate the backhoe design on the Kubota would be probably be an example of that.
Everyone gets to make their own choices and would get a good, hardworking tractor with either choice.
   / BX25 vs XJ2025: ground clearance #3
To best evaluate ground clearance for that xj2025 and a kubota bx25 and a massey 1720 . . You should measure the low points on all three on the backhoes when they are not having their extension supports out or fel or hoe buckets raised. As I recall both the kubora and massey advertise their backhoe mount angle at 20 degrees or more . . Again relating to clearance. Backhoes are heavy . . Then add the operstor in the seat besides . . . And bigger units can get "small" when it comes to backhoe clearance.
   / BX25 vs XJ2025: ground clearance #4
That frame looks like a real kludge on the LS, and something I'd sure want to know before I purchased! I'd hate to discover that after the fact.
I'm comparing all the tractors in the same price range...
GC1710, BX25D, SC2410, XJ2025, and eMax25... 1025R and Max25 are off the table because of price.
LOL kludge is the right word.
   / BX25 vs XJ2025: ground clearance #7
I would think a BX25d would be priced higher than the gc1720 and the gc1710 would be $1200 to 1500 cheaper than the gc1720. Also . . I'm familiar with the sc2400 and the sc2450. What is a sc2410 ??
BX25D-1: 17,050
CS2410: 17,400
eMAX 25: 16,900
GC1710: 16,900
XJ2025: 18,800
Typo on the Kioti. I rented the BX last weekend. I'm going to try out the Kioti and Mahindra this weekend. LS is going to bring a demo by next week.
   / BX25 vs XJ2025: ground clearance #9
Another ground clearance to check if the height when a mower deck is installed. Its another place the BX is several inches ahead of most everything else.
Not buying it to mow. Not one of my considerations. Thanks though.
2008 Ford F-250 Pickup Truck (A50323)
2008 Ford F-250...
1994 FORD F450-SUPER DUTY FLATBED (A51222)
1994 FORD...
2022 CATERPILLAR 335 EXCAVATOR (A51242)
2022 CATERPILLAR...
Hours : 1114 (A50323)
2025 Single Cylinder 40in Grapple Rake Mini Skid Steer Attachment (A50322)
2025 Single...
CATERPILLAR 257B SKID STEER (A51242)
CATERPILLAR 257B...
