Duct Cleaning -- and then the upsell
   / Duct Cleaning -- and then the upsell #31
I'm with those who said duct cleaning is a waste of time and money. My guess is that it's never needed and a total scam. The filter does all the work, make sure you change your filter once a month and you add bleach to your drain. Odds are that if you run anything through your duct, you risk opening up a duct and creating a problem that was never there before.
   / Duct Cleaning -- and then the upsell #32
While we were building our new house, when it was close to complete, we spent a weekend "camping" there and brought our two cats. We had an open 4x8 floor register opening underneath where the kitchen cabinets were going to be installed, so it had no actual register installed. To my amazement, our little cat went down it and got stuck about 18" in. To try to prevent her from going any farther and winding up on top of the evap coil, I squeezed down the duct just in front of her. Luckily, had good access in the open basement. Like to NEVER got that cat back out! Thought I was going to have to pull duct connections apart or cut them! Did you know you can pull on a cat's tail REALLY hard without it coming off?
   / Duct Cleaning -- and then the upsell #33
I'm sorry, but that's funny! :D
<OS_dispatch_group: 0x1460d430>
   / Duct Cleaning -- and then the upsell #34
Thanks to all who responded. I think I'll forgo any duct cleaning.
   / Duct Cleaning -- and then the upsell #35
Add bleach to what drain?
   / Duct Cleaning -- and then the upsell #36
Evaporator pan drain from the AC to keep the crud out. I use AC pills for that,they are time released.
   / Duct Cleaning -- and then the upsell #37
My AC unit has a piece of pvc pipe going over to the floor drain.
   / Duct Cleaning -- and then the upsell #38
You need to watch the pipe from the AC to the floor drain. Short runs really don't clog like long straight runs.
   / Duct Cleaning -- and then the upsell #39
My drain pipe is pretty short, probably down 4 feet and over 4 feet
   / Duct Cleaning -- and then the upsell #40
DRILL CABINET SKID (A55745)
DRILL CABINET SKID...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
2003 SHOPMADE GOOSENECK CASING DRILL PIPE HANDLER TRL (A55745)
2003 SHOPMADE...
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A51691)
1996 JLG Commander...
FIAT ALLIS FD145 CRAWLER DOZER (A52707)
FIAT ALLIS FD145...
