LED Garage Lights
   / LED Garage Lights #171
I put my 30 x 48 barn on 4 switches, 12 lights. Well, i will when it's finished.....
   / LED Garage Lights #172
Aaron, I wonder how the 20 watt LED lights would work to night light my flags on two 30' flag poles? They are supposed to be waterproof.
I am not sure it will be focused enough, they are a pretty wide angle light. Two of the 10 watt versions (LE® 10W LED Flood Lights, LED Outdoor Lighting, 100W Halogen Bulb Equivalent, 700lm, Waterproof, 6000K Daylight White, LED Security Light, Floodlight, Pack of 3 Units - - Amazon.com) have a wider beam than 3 PAR38 floodlights.
They would probbaly work if you could mount them on the top.
Aaron Z
   / LED Garage Lights #173
   / LED Garage Lights #174
   / LED Garage Lights #175
Those look interesting but, not sure that 10 watt LED will give me enough light for flags 30' above the ground?
   / LED Garage Lights #176
Has anyone tried using one of the Costco or Sam's fixture as a "plug-in" on a garage door opener? Our openers currently have a feeble incandescent that lights a little bit between the power head and the door, but the remaining 40 ft to the basement door stays quite dark. I was thinking of just using one of these
and plugging it in. Is the current draw of the LED fixtures in the same ballpark as an incandescent bulb or two? I once tried CFLs in a GDO, but the current draw was too low to properly cycle what was evidently a thermal timer circuit - the CFL never turned off!
I guess even if the current draw is very low, one of these
along with an incandescent would work.
   / LED Garage Lights #177
I'm anxious to see my 24x30' workshop when I take out my 6 double 2' 1" flourescents and put in 8 costco LED fixtures. Should be coming soon/
Will you put them all on one switch or alternate?
Not sure if you are addressing me, but I plan on 2 switches and then the florescents I plan to reuse directly over the workbenches with another switch. Nice thing about the Costco lights is the pull chain so they can be shut off if all aren't needed.
   / LED Garage Lights #178
I used two of the screw in plugins, ran extension cord to extend beyond the door edge, into a receptacle box to hold a LED spot light on each side of the door, which is very helpful lighting the shop while the door is open.
   / LED Garage Lights #179
I switched everything out like I wanted to. Now it looks like an operating room a split second after I flip the switch. It is now a pleasure to step into the workshop.
   / LED Garage Lights #180
I noticed that the latest Costco flyer has the Feit's on sale. IIRC, they were $23.99.
My two have been working awesome plugged into the GDO. I actually USE the "light" button on the opener remotes a lot now. Just the one LED shop light does a great job of providing enough light throughout the entire basement to safely navigate through. If I happen to accidentally leave one or both on all night, I don't really care.
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
2023 CATERPILLAR 299D3XE SKID STEER (A51242)
2023 CATERPILLAR...
2005 Morgan Corporation Flatbed Body (A50854)
2005 Morgan...
2018 INTERNATIONAL LT625 TANDEM AXLE DAY CAB (A51219)
2018 INTERNATIONAL...
2008 New Holland B110 MFWD Loader Backhoe (A51039)
2008 New Holland...
NEW 2022 Load Trail CH 83IN x 18FT Equipment Trailer (A51039)
NEW 2022 Load...
