Synthetic oil worth it? 18k hour yamaha generator says no.
   / Synthetic oil worth it? 18k hour yamaha generator says no. #31
   / Synthetic oil worth it? 18k hour yamaha generator says no. #32
   / Synthetic oil worth it? 18k hour yamaha generator says no. #34
i already posted the link from the ventrac that says recommended. their manual also says to follow the engine manufactures recommendations.
saying no doesn't change that without documentation.
   / Synthetic oil worth it? 18k hour yamaha generator says no. #36
What I got that came with my Book was a 4x6 size oil requirements guide from Ventrac. That also said they were filled with Mobil 1 from the factory. The kubota book does NOT require synthetic.
Edit, I found the card and must eat some crow as they Advice me to use Mobil 1 oil that comes installed from the factory. You were right not a requirement.
   / Synthetic oil worth it? 18k hour yamaha generator says no. #37
I don't think any manufacturer can 'require' the purchaser to use one type /brand of oil over another due to some lawsuits filed several decades ago (remember when Ford only allowed Formoco oil or warranty would be voided?) Several class action lawsuits later and there is no more 'required' uses of brand name oil, only API service grades and weights are listed in manuals now.
It is largely up to the owner of equipment to select the type of oil that they use whether it be straight mineral oil, regular motor oil or synthetic as long as the type is what the manufacturer lists as required.
My interpretation of 'Strongly recommended' would be "required" by manufacturer and still not be breaking the law. They could not void warranty if you used any other oil that is listed in their manual but by using the recommended oil, you WILL have better operation and possibly longer service life of the engine.
Bottom line, use whatever YOU want LittleBill21 from PA., but don't try to argue the semantics point that no where is it "required" when it certainly is recommended in many manuals.
A good example of recommended vs required would be if I recommended that you don't jump out of an airplane without a parachute, would that be a requirement? NO, you could still do it, but might not be the best thing in your interest.
   / Synthetic oil worth it? 18k hour yamaha generator says no. #38
My oil is better than your oil.
   / Synthetic oil worth it? 18k hour yamaha generator says no. #40
I'm still trying to figure out how 20 hours a day for 17 months equals 18k hours.
CATERPILLAR D8T HI-TRACK CRAWLER DOZER (A50458)
CATERPILLAR D8T...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
2017 FREIGHTLINER M2 BOX TRUCK (A51222)
2017 FREIGHTLINER...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
2023 John Deere 8R410 MFWD Tractor (A52128)
2023 John Deere...
2014 Gillig 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig 31+56...
