3 point lift capacity with boom pole
   / 3 point lift capacity with boom pole #11
I found a used engine puller (cherry picker to some). Made a bottom plate to fit the lift bars and a bracket to hook up the top link. It works like a charm!!! You have the tractor lift along with the picker lift (that changes the lift point==pivot point of lift). It can be shortened for heavy loads or lengthened for lighter things. I've raised things over the side of a pickup bed with mine.
   / 3 point lift capacity with boom pole #12
Here's a store bought receiver hitch style. There is a leg directly under the vertical part that must be put down on the ground if picking up any significant load.
I use it to unload the pickup occasionally.
I have it mounted on a Titan 3point receiver hitch attachment here.
I am looking at these two -
CountyLine Boom Pole - For Life Out Here
CountyLine Heavy-Duty Boom Pole - For Life Out Here
What sparked my question was the front loop capacity; on the smaller boom ,it is only 500lbs. That did not seem like much, given the tractor capacity
is listed as 1400 lbs 24 inches behind the hitch.
I understand a bit more now (thanks LD1)- 500lbs on the front loop, with the 3pt at it's highest lift, on the 'right' top link hole, my be at or near the tractor capacity.
I am still leaning toward the heavy duty pole, simply from a stability and durability standpoint. It is twice as heavy as the small boom though - and twice the cost. Hmmm.
   / 3 point lift capacity with boom pole #14
What do you plan on lifting?
In reality, the lighter one would probably be just fine. I am sure there is a nice safety factor built in as well. We have one of them lighter ones. Used it on the back of an international 444 to lift an entire loader/bucket onto the trailer when purchasing. Guessing 1000#+.
THe heavy one sure looks nice though, and has a third toplink hole as opposed to two to further taylor the lift height/capacity
That's the kind of question my bride asks, and I have to think quick to come up with a good answer.
We just bought a farm that has 3 generations of 'stuff' laying around. I need to clear then start setting up for us.
But really - I just want more toys for my tractor.
   / 3 point lift capacity with boom pole #16
....But really - I just want more toys for my tractor.
There's nothing wrong with that!! :thumbsup: I had 2 boom poles - only used the larger one, one time. Do you not have a Front End Loader??? I found it easier to use the FEL instead of the boom pole.
I got rid of both of them, gave them away to friends, one that didn't have a FEL and the other had a small limited size FEL. If you don't have a FEL, if you try to lift too much, you'll most likely only lift the front of your tractor :D
BOMAG BW145D-40 SMOOTH DRUM ROLLER (A51246)
BOMAG BW145D-40...
2010 THOMPSON TRASH PUMP (A51406)
2010 THOMPSON...
2003 GMC C7500 16ft Cab and Chassis Truck (A51692)
2003 GMC C7500...
UNUSED LANDHERO MIG-140 WELDING MACHINE (A51248)
UNUSED LANDHERO...
11' CONTAINER (A51248)
