3 point lift capacity with boom pole
   / 3 point lift capacity with boom pole #11
I found a used engine puller (cherry picker to some). Made a bottom plate to fit the lift bars and a bracket to hook up the top link. It works like a charm!!! You have the tractor lift along with the picker lift (that changes the lift point==pivot point of lift). It can be shortened for heavy loads or lengthened for lighter things. I've raised things over the side of a pickup bed with mine.
   / 3 point lift capacity with boom pole #12
Here's a store bought receiver hitch style. There is a leg directly under the vertical part that must be put down on the ground if picking up any significant load.
I use it to unload the pickup occasionally.
I have it mounted on a Titan 3point receiver hitch attachment here.
I am looking at these two -
CountyLine Boom Pole - For Life Out Here
CountyLine Heavy-Duty Boom Pole - For Life Out Here
What sparked my question was the front loop capacity; on the smaller boom ,it is only 500lbs. That did not seem like much, given the tractor capacity
is listed as 1400 lbs 24 inches behind the hitch.
I understand a bit more now (thanks LD1)- 500lbs on the front loop, with the 3pt at it's highest lift, on the 'right' top link hole, my be at or near the tractor capacity.
I am still leaning toward the heavy duty pole, simply from a stability and durability standpoint. It is twice as heavy as the small boom though - and twice the cost. Hmmm.
   / 3 point lift capacity with boom pole #14
What do you plan on lifting?
In reality, the lighter one would probably be just fine. I am sure there is a nice safety factor built in as well. We have one of them lighter ones. Used it on the back of an international 444 to lift an entire loader/bucket onto the trailer when purchasing. Guessing 1000#+.
THe heavy one sure looks nice though, and has a third toplink hole as opposed to two to further taylor the lift height/capacity
That's the kind of question my bride asks, and I have to think quick to come up with a good answer.
We just bought a farm that has 3 generations of 'stuff' laying around. I need to clear then start setting up for us.
But really - I just want more toys for my tractor.
   / 3 point lift capacity with boom pole #16
....But really - I just want more toys for my tractor.
There's nothing wrong with that!! :thumbsup: I had 2 boom poles - only used the larger one, one time. Do you not have a Front End Loader??? I found it easier to use the FEL instead of the boom pole.
I got rid of both of them, gave them away to friends, one that didn't have a FEL and the other had a small limited size FEL. If you don't have a FEL, if you try to lift too much, you'll most likely only lift the front of your tractor :D
66 Tomahawk Skid Steer Bucket (A52384)
66 Tomahawk Skid...
UNUSED AGT SAWMILL MODEL - YC32G (A51248)
UNUSED AGT SAWMILL...
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
51" HANG ON WHEEL LOADER FORKS (A51246)
51" HANG ON WHEEL...
22002 (A51694)
22002 (A51694)
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
