Engaging 4WD on Ford/New Holland 2120
   / Engaging 4WD on Ford/New Holland 2120 #1
Zerk
Wisconsin/UP
New Holland 2120
I can't get the 4wd to stay engaged on my 1995 2120, unless I hold the the lever down with my foot. Am I doing something wrong? Something need to be lubed or iced up?
Thanks.
   / Engaging 4WD on Ford/New Holland 2120 #2
Are you talking about the diff lock or the 4wd? On my 2120 the 4wd lever is up for 4wd, not down.
Jim
   / Engaging 4WD on Ford/New Holland 2120 #3
Diff lock is on the right, yes it must be held down.
Ed
   / Engaging 4WD on Ford/New Holland 2120 #4
Ed L is correct. The diff lock may stay engaged after you release your foot from the pedal if the rear wheels are turning at different speeds. It will release once you're going straight again.
Jim
   / Engaging 4WD on Ford/New Holland 2120 #5
Ed
The OP may be confused about the two controls.
He was enquiring about engaging the 4WD, not the differential lock.
He may be pushing down on the diff lock, thinking it will engage 4WD.
As jimmysisson noted: The 4WD is only engaged by pulling the 4WD T-handle UP.
I am trying to engaging differential lock. Lever by my right foot.
I can't keep them both locked, unless I keep the lever held down.
   / Engaging 4WD on Ford/New Holland 2120 #7
Why do you need your diff lock engaged for long periods?
I use mine when pushing into a pile of material. Once the bucket is full and I reverse it disengages. I also use it to get better traction in soft, soupy ground.
   / Engaging 4WD on Ford/New Holland 2120 #8
I am trying to engaging differential lock. Lever by my right foot. I can't keep them both locked, unless I keep the lever held down.
That is how it works. As soon as you push down it engages. Lift your foot off it disconnects.
That is a crappy design. So you if you are or on mud or ice you must keep your foot on it the whole time. I would have expected it to stay locked until released.
Anyone ever modified it to stay locked? Maybe something as simple as tieing it down when needed. Any negatives to this?
   / Engaging 4WD on Ford/New Holland 2120 #10
Are you confusing the differential lock with 4WD? I'm asking since your thread is titled "Engaging 4WD...". 4WD stays engaged until you move the 4WD lever to disengage it. Differential lock will cause binding while turning, and is typically only used sparingly so that pedal has to be held in place to keep it engaged. Your set up is typical of many (most?) tractors.
2014 INTERNATIONAL MA025 (A52472)
2014 INTERNATIONAL...
2001 CATERPILLAR IT28G (A52472)
2001 CATERPILLAR...
JOHN DEERE 461R LOT NUMBER 61 (A53084)
JOHN DEERE 461R...
Tiger Mower Hydraulic Tank Connection (A51691)
Tiger Mower...
KMC 5610 LOT NUMBER 33 (A53084)
KMC 5610 LOT...
2015 INTERNATIONAL MA025 (A52472)
2015 INTERNATIONAL...
