My Kioti NX6010 tractor now has about 250ish hours.
My tractor was sold to me as regenerating about every 50 hours with an expected life of the DPF of 2000-3000 hours.
In actual use, the tractor was regenerating every 8-12 hours meaning that 40 to 60 regeneration cycles would have me replacing the DPF at 320 to 480 hours.
Stock, the engine engine would never warm up in cool to cold ambient temperatures unless I was doing ground engagement tasks or traveling in high gear. Since most of my work is easy loader work, the engine would not warm up and would remain in the engine management system's warm up fuel map and run in a rich state that put more exhaust soot through the diesel particulate filter leading to increased frequency of regeneration cycles. Because the engine was not warming up, the engine management system was not flagging the need for regeneration and this led to greatly reduced power until I was able to get the engine warmed up so as to allow the system to regenerate.
This was a major headache that left me seriously discouraged about my purchase.
I read up on the problem with other OEM's DPFs and learned that those of us in colder climates were having a similar experiences as myself. Fleet managers especially were deeply concerned. Frequently OEMs refused to acknowledge the problem, but for those OEMs that did, their field fix was to install a thermostat that allowed the engine to further warm up before opening.
Thankfully, as a former auto tech, I still know people running massive jobber parts stores, and so a friend and I sat down measuring the stock T-stat, and looking for alternatives that would fit, and also feature a bypass like the stock thermostat (a bypass allows coolant to bypass the T-stat when the throttle is opened up).
I then compared the stock T-stat with my alternative T-stat in water brought to a boil so as to confirm both fit and performance.
To be clear, the fully open temperature of 180°F of the new T-stat is the same as the stock T-stat. All the new T-stat does is begin opening at 170°F rather than 160°F and what a positive improvement it is! I am now regenerating every 20-40 or so hours instead of every 8-12 hours because the engine can warm up quicker to normal operating temperature rather than remaining continually on the warm-up fuel map, run rich, and in so doing rapidly clog the exhaust diesel particulate filter (DPF) with soot. Just to be clear: no matter what temperature the engine is running at, it runs with the factory fuel map, and all I've done is shorten the warm-up cycle, a cycle that the stock T-stat would prolong because most of my work is low-stress loader work that is performed frequently during cool to cold ambient temperatures. Under a load, with a warm engine, my solution runs no hotter than the stock T-stat.
You can see from my zillion videos, that the engine still runs at the normal operating temperature regardless of ambient temperature.
