Hydraulic power being priority in a purchase.
   / Hydraulic power being priority in a purchase. #11
The GC are nice little machines. The 2410/2610 are the predecessor to the 17xx models. Back when I was shopping (ended up with my B3300) I liked the GCs FAR better than the BXs.
As was mentioned, force is usually more important than the speed. Unless you are using it commercially, a few extra seconds here and there will never be noticed especially if you are not operating them both side-by-side for direct comparison.
For example, If you compare the available lift of the GC vs BX, there really isn't much comparison:
GC 870 lbs at the pin
BX 745 lbs at the pin
That 125 lbs extra lift on the GC is HUGE. I'd happily loose a couple extra seconds for that difference.
   / Hydraulic power being priority in a purchase. #12
That's another topic. Some brands, or dealers, call them tlbs, others claim completely different classes for hp and weight etc.
Interesting. It's hard to tell what the difference is in that tractor and a regular (non TLB) version.
I think you are wise to be researching this. I had a bobcat 45 HP tractor and after doing some research I found that it did not offer enough flow or pressure to operate most skid steer attachments that required continuous flow. Skid steers run around 20 gpm at 2,000+ psi and it only ran like 7 gpm at 1500 psi. Being able to use attachments from walk behind skid steers such as a trencher would be really useful on a little tractor like what you are looking at.
One way to get higher flow from a small tractor operating a backhoe is to buy a backhoe with it's own hydraulic system and pump that hooks to the PTO. Those can give you significantly more flow and faster operation than using the tractor's hydraulic pump.
I love the idea of a compact TLB. I guess these woudl be the closest thing I've seen to one.
   / Hydraulic power being priority in a purchase. #13
Kubota still makes a subcompact and a compact TLB.
   / Hydraulic power being priority in a purchase. #14
GC 870 lbs at the pin & 920 at the bucket edge
BX 518 lbs at the pin & 745 at 500mm forward (bucket edge?)
something is wrong with your numbers. The pin numbers should be higher than bucket center numbers. (or did you pull roll back?)
flow is not a great way to guess speeds. Cylinder size, geometry,etc all make a huge difference that.
Kubota publishes speeds for most of their implements.
best way to do this process is get your butt in the seat and run some tractors. Spreadsheets are deceiving.
almost never done any more. Most tractor hydraulic systems outflow the PTO pumps recommended for a given backhoe or other attachment.
   / Hydraulic power being priority in a purchase. #15
"best way to do this process is get your butt in the seat and run some tractors. Spreadsheets are deceiving."
I tell all the newbies that and not many of them listen.
   / Hydraulic power being priority in a purchase. #16
A bobcat usually has the high flow option available. You need it for the equipment like a bush hog. Get what you want going in - it gets expensive to bring things up to speed after you have purchased.
   / Hydraulic power being priority in a purchase. #17
So you are saying that this tractor can push more flow than a PTO hydraulic pump?
My math comes up with a different answer. I see the ability to flow more than double that 5-7 gpm output with a PTO pump?? What am I missing?
   / Hydraulic power being priority in a purchase. #19
Subcompact TLBs:
Kubota BX25
Massey GC xx10
Deere 1 series
Not much difference between a tractor with a subframe BH and a TLB. Sure, a true TLB is a bit heavier but I doubt there is much performance difference
   / Hydraulic power being priority in a purchase. #20
Those Terramite units are actually pretty strong, much more so than the SCUT TLB's u listed
1992 DFI PULL SPREADER (A58375)
1992 DFI PULL...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A55973)
1993 Ingersoll...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
2001 FREIGHTLINER FL70 (A58214)
2001 FREIGHTLINER...
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A56859)
2004 Fleetwood...
2012 Chevrolet Silverado 2500HD 4x4 Service Truck (A56858)
2012 Chevrolet...
