Which Bucket to buy for LA805 loader
   / Which Bucket to buy for LA805 loader #1
kubotacres
Gold Member
Louisiana
Kubota L3560 HST
So I've researched and still haven't found the answer I'm looking for. I was quoted a LA805 loader with a L2236 bucket (72" QA). The bucket is considered "light material". The other bucket I'm considering is the L2235A which is the Square back bucket at only $40-$50 more. However I can't find any comparison on these two buckets or photos to see the difference. I also see the roundback bucket which I'm not considering. Can anybody shed some light on this? Thanks,
   / Which Bucket to buy for LA805 loader #2
The standard square-back bucket has been amply rugged enough for just about any reasonable use we've ever had. The standard 6 ft. Kubota bucket weighs more than 300 lbs... you'd have to be constantly prying loose boulders or something equally destructive to need something heavier... really not the type of work tractors like this were designed for... just my opinion. Can't tell you about the "light material" bucket, but unless you're only working with mulch or something, the standard bucket is a pretty good all-around choice.
   / Which Bucket to buy for LA805 loader #3
I agree, opt for the heavier bucket
   / Which Bucket to buy for LA805 loader #4
I would recommend the HD round-back bucket;the light materials
bucket(lot more volume) are used mostly for snow removal up north.
I was under the impression that the " light material" was considered the standard bucket.... What is the difference between the light and the square? Which one is superior?
   / Which Bucket to buy for LA805 loader #6
Normally the light materials bucket option lets you get a wider bucket on a loader. But since the bucket has higher volume than the standard bucket, they rate it to carry less dense material. Idea is it would be for moving larger quantities of lighter material.
   / Which Bucket to buy for LA805 loader #7
Don't think that's correct. The "Build My Kubota" app on the Kubota website lists 4 different bucket options for the Grand L's: 1) Light Material, 2( Standard Square Back, 3( Heavy Duty Round Back, and 4( 4 in 1. I've been using the standard square bucket for 14 years of serious use (ex: digging piles of 10-12" rip-rap, carrying logs up to 2,000lbs using pin-on forks, moving Lord knows how much material, etc.), with no warps, cracks or bends of any kind. Seriously, unless you expect to do something really extreme, the standard bucket is plenty rugged. Here's a pic of the standard bucket on mine.
Here are LA805 bucket specs from the Kubota Canada website, where both square and round back buckets are called "standard":
Standard bucket
Width 72 in. (1830 mm)
Type Quick attach
Depth Round 72'' 18.0 in. (458 mm) Square 72'' 547mm (21.5 in)
Overall height Round 72'' 23.9 in. (608 mm) Square 72'' 570mm (22.4 in)
Length Round 72'' 24 in. (610 mm) Square 72'' 630mm (24.8 in)
Standard
Capacity - struck 10.9 cu. ft. (0.31 mウ)
Capacity - heaped 13.1 cu. ft. (0.37 mウ)
Standard bucket
Weight Round 72'': 397 lbs. (180 kg) Square 331 lbs. (150 kg)
Can't swear to it but some checking seems to suggest the Kubota "Light Material" bucket is a snow bucket. Here's a link with a photo of one:
http://www.tractorbynet.com/forums/attachments/268362-kubota-light-materials-bucket-too.html
Any decent dealer should have all the details about this.
Hope this is helpful.
   / Which Bucket to buy for LA805 loader #8
I got the heavy duty round back bucket for mine and I have to say that I wish I had looked at the capacity before ordering. It is hefty, especially with the add on cutting blade,but it is a pretty small bucket.
Standard bucket
Type Quick attach
Standard
Standard bucket
Thank you for this.. Just the info I needed. I'm going with the square which seems to be the standard. Looks the same that was on my 524 loader.
   / Which Bucket to buy for LA805 loader #10
Go with the 4n1 you will never have anything but once you have one. I can figure how to post photos from my phone but my 4n1 gets used a lot, and I do have a grapple also.
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
Cat CB24B (A60462)
Cat CB24B (A60462)
2016 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A60429)
2016 CATERPILLAR...
2017 Ford Escape SUV (A59231)
2017 Ford Escape...
Club Car 4x4 Diesel Utility Cart (A59228)
Club Car 4x4...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A56858)
Pallet of...
