No Hot Water Heaters over 50 gallons now at Lowes or Home Depot
   / No Hot Water Heaters over 50 gallons now at Lowes or Home Depot #41
The problem is copper to galvanized. (electrolysis) If the 3/4" female adapter was brass no problem. Or at least less problem.:)
Zerk I'm curious what a struggling **** star needs to ground while at work. :D
I doubt he knew enough to use brass. Galv and copper are what most people would have used, if they didn't know better.
I had to take a day job, to make ends meat.
   / No Hot Water Heaters over 50 gallons now at Lowes or Home Depot #42
I wanted them set up as I could pull either 1 out of service and still use the other 1.Right now 1 feeds into the other like a preheater. The dielectrics are on the hot water tanks.
I have wondered what effect parallel tanks would have, I am thinking about doing it pressure tanks for my camp well, one above ground for summer. I toll like the idea of being able to take one out of service. I am a big believer in being ready for a failure and having back up. If not parrallel, I would have done by pass valves.
   / No Hot Water Heaters over 50 gallons now at Lowes or Home Depot #43
You shouldn't have to register a water heater, like a firearm.
   / No Hot Water Heaters over 50 gallons now at Lowes or Home Depot #44
In many jurisdictions now, expansion bladder tanks are required, but homeowners/DIYers tend to skip the extra plumbing and expense of installing them. .
When using multiple tanks or as anti scald measure? I have been out the industry for awhile. Plus I never lived in a house with a pressure tank. So far so good.
   / No Hot Water Heaters over 50 gallons now at Lowes or Home Depot #45
"A well regulated shower, being necessary to the serenity of a free household, the right of the people to keep and bear water heaters, shall not be infringed."
Bruce
   / No Hot Water Heaters over 50 gallons now at Lowes or Home Depot #46
I have commercial, institutional and residential... yet to have a pressure tank.
   / No Hot Water Heaters over 50 gallons now at Lowes or Home Depot #47
   / No Hot Water Heaters over 50 gallons now at Lowes or Home Depot #48
I have two water heaters in series. I think this is the correct way to do it.
If you have two parallel tanks, how do you intend to balance the flow? And, how do you propose to keep it balanced as the system ages and changes slightly?
At least with the tanks in series, the same amount of water goes through both of them. I have never had a problem with my installation in 8 years of experience.
   / No Hot Water Heaters over 50 gallons now at Lowes or Home Depot #49
Studying the pic..(I have no idea which lines are hot and cold), one more valve on the horizontal connector (in the pic I is the line just below the gas valve), and you could UN parallel, series, or either of the tanks as a single
   / No Hot Water Heaters over 50 gallons now at Lowes or Home Depot #50
Facing the front of the water heaters; the cold is always on the right. This could be changed by switching the dip tube from the right hole to the left. Never had to do that.
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A53426)
2016 FREIGHTLINER...
2011 Homesteader Box Trailer, 6'x10' (A52384)
2011 Homesteader...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A53426)
2020 FREIGHTLINER...
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A52377)
2013 Chevrolet...
100 FUEL TANK (A53843)
Ford Super Duty 8ft. Truck Bed (A51692)
Ford Super Duty...
