Cutting Red Willow bushes in pasture with skidsteer, Brush cutter or Scissor cutter?
   / Cutting Red Willow bushes in pasture with skidsteer, Brush cutter or Scissor cutter? #1
thorholt
Mn
Kioti RX6010PC
Hello Everyone, I need to cut down some brush in a old crp field, Red Willow bushes, they grow in clumps with each branch about 1\2-3\4" diameter, I was looking at either a skidsteer brush cutter or one of those shears the mount on the front of the skid steer, I know the brush cutter will do the job but they are expensive and I really have no use for one when done with it, The shears are reasonable but never seen one in action in this situation, I do have a good bush hog type mower for my tractor but prefer not to beat up the tractor running down the brush before it gets cut, If I sheered it with the skid steer then ran the mower over it to grind up or gather it up and burn it, Any advise? It is about 40 acres of random brush to clean up. Thanks
   / Cutting Red Willow bushes in pasture with skidsteer, Brush cutter or Scissor cutter? #2
Is renting a skid steer brush cutter an option? I'd try to kill the brush and them burn it in place.
   / Cutting Red Willow bushes in pasture with skidsteer, Brush cutter or Scissor cutter? #3
You have a free bushog - the ideal tool. It does not hurt a tractor to run over twigs.
I wish there was one to rent locally but I haven't found one, I will kill it this spring when it greens up but burning might be tough as they are spread apart quite a lot and I am surrounded by woods and would be nervous of the fire getting away from me.
Some are 10' high it would scrape up the tractor pretty good, I tried a few last fall, it does work but not very good, A lot of them pop back up after I drove over them requiring me to drive over them again from the opposite direction.
   / Cutting Red Willow bushes in pasture with skidsteer, Brush cutter or Scissor cutter? #6
How about backing the bush hog over the willows if you don't want to drive over them first? I do this all the time on locust with my M7040 and Land Pride cutter.
   / Cutting Red Willow bushes in pasture with skidsteer, Brush cutter or Scissor cutter? #7
Hm-m ... Ive done exactly that type of stuf, but I think my setup was probably better suited. My JD 127 Gyramor cutter is narrower than my wheel track and the blades swing near the bottom of the side skirts - and well below the front skirt. ... So the stuf is not broken down, only bent, as it goes into the exposed blades. This gives a clean cut. Very satisfying.
   / Cutting Red Willow bushes in pasture with skidsteer, Brush cutter or Scissor cutter? #8
If my little 22-hp Kioti can ride over something and bend it over my very light duty rotary mower will chop it up. Just ease up slowly over the clumps and wear ear plugs. Even a light duty mower will chop up 1/2" stuff.
   / Cutting Red Willow bushes in pasture with skidsteer, Brush cutter or Scissor cutter? #9
The problem with tall, thin stems is that they lie flat, held down by the cutter, the cutter rides over them, then they pop up.
Bruce
   / Cutting Red Willow bushes in pasture with skidsteer, Brush cutter or Scissor cutter? #10
Anytime all I break is shear bolts, I call it a good day. If I had to worry about getting my equipment scratched it wouldn't do me much good.
PumpJack Brand Pump Jack (A53472)
PumpJack Brand...
JOHN DEERE 3 BOTTOM PLOW (A51247)
JOHN DEERE 3...
UNUSED CFG INDUSTRIAL EXCAVATOR ATTACHMENT SET (A51248)
UNUSED CFG...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
UNUSED AGT LRT23 STAND ON SKID STEER (A51247)
UNUSED AGT LRT23...
2007 International 7500 sba Flatbed 6x6 Truck (A52384)
2007 International...
