No Hot Water Heaters over 50 gallons now at Lowes or Home Depot
   / No Hot Water Heaters over 50 gallons now at Lowes or Home Depot #71
   / No Hot Water Heaters over 50 gallons now at Lowes or Home Depot #73
If we wait long enough the may succeed or be annexed by Mexico.
   / No Hot Water Heaters over 50 gallons now at Lowes or Home Depot #74
Lex Luther had the right idea. Nuke the San Andreas fault. :)
I do live on the fault... through no fault of my own being born here.
Geologic activity has made some of the most interesting places... the Hawaii Islands, SF Bay Area... parts for Oregon and Washington... the Ring of Fire.
   / No Hot Water Heaters over 50 gallons now at Lowes or Home Depot #75
"A well regulated shower, being necessary to the serenity of a free household, the right of the people to keep and bear water heaters, shall not be infringed." Bruce
Yes but what constitutes a "well regulated" shower? Isn't the permit process insurance that the shower will be well regulated and safe?
   / No Hot Water Heaters over 50 gallons now at Lowes or Home Depot #76
The regulator is on the shower wall.
Bruce
FYI, the IPC (remember it is a model code so local jurisdiction may be different) states that max temperature at outlets be restricted to 110 degrees F to prevent scalding. As was stated earlier that is too low to prevent bacteria from growing in the HW tank. W/O an anti scald valve or shower valve that includes it that is then the HW tank setting. Commercial work commonly sets WH at 150 degrees F and uses mixing valves at the fixture. I just finished a test protocol that included all those features for a VA facility.
Ron
Ron
Ron I have my mixing valve ordered so do not have to worry about burns. It comes set at 120F and expect I may leave it there for the clothes/dish washers.
My question can these fail and let out only hot water or does it default to cold? This is the one I ordered based on reviews. HEATGUARD Thermostatic Mixing Valves TMV HG110D LF w/ 3/4" Sharkbite Ends BNIB
   / No Hot Water Heaters over 50 gallons now at Lowes or Home Depot #78
I've resisted upgrading at the rentals... did one and it has been a nightmare.
The water system is 100 years old and any sediment or scale screws up the mixing valve... NEVER had that problem with the old two handle Hot and Cold shower/tub combos.
All the water saver features are predicated on water free from sediment...
   / No Hot Water Heaters over 50 gallons now at Lowes or Home Depot #79
I had sediment problems for years until I installed a Y strainer and filter for the whole house. It didn't cost very much but sure has made a difference in valves lasting longer without any problems.
Every month or so I open the valve under the Y strainer and blow out any sediment. The filter lasts about 1-2 years.
   / No Hot Water Heaters over 50 gallons now at Lowes or Home Depot #80
I do have similar in Washington with well water... also have a basement.
The areas with the problems are rentals in San Francisco... water lines are exposed outside and then run under a slab... or into a 12" crawl space.
The only way to add would be outside between the meter and the house and with some that would be on the sidewalk.
So far the only problems have been in the homes with upgraded mixing valves.
Krause Dominator 4850-18ft (A53473)
Krause Dominator...
1270 (A50490)
1270 (A50490)
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A52472)
2013 XLR...
Large Metal Rooster Lawn Art (A51694)
Large Metal...
JOHN DEERE 7300 LOT NUMBER 18 (A53084)
JOHN DEERE 7300...
Towable Orchard Sprayer (A51691)
Towable Orchard...
