1970 ford 4000 3cyl diesel adding the HV4902 adapter plate
   / 1970 ford 4000 3cyl diesel adding the HV4902 adapter plate #1
viziers
Member
North Carolina
1970 Ford 4000 3Cyl Diesel
Hello All. I am very new to tractors and especially hydraulics and have gone with the advice of some of the members here already.
I already ordered Brian's TL from fitrite and already have a 2 SPOOL 8 GPM PRINCE MB21BB5C1 DA VALVE (may replace that valve with the other one with the float feature for the top link) and have
the HV4902 plate.
The reason for this thread is because I am very confused about the hookups for the HV4902 and a 2 spool valve that has a PB port on it... Does the PB port have to be routed back into the 3pt hydraulic reservoir for the 3pt hitch to work properly like in through the fill plug on the rear axle or is the PB port not used and the 3ph hitch will work normally?
vizi
   / 1970 ford 4000 3cyl diesel adding the HV4902 adapter plate #2
hv5902 kit is the one for power beyond valves....
Yes that is correct but that plate is not meant for my model per YT site and a couple others. So is it safe to assume that I need not worry about the PB on the valve and the the setup will not interfere with the 3pt system?
Hey soundguy that 2 spool valve you recommended that I acquired, should I have gotten the one with the float function being one of the 2 sides will be used for the top link??
vizi
   / 1970 ford 4000 3cyl diesel adding the HV4902 adapter plate #6
If you have a PB valve, you would be matched to a PB plate.
can you use the pb valve on a regular plate.. probably.. I'm not familiar with your valve. JJ can probably help you there. I've seen many PB capable valves that can certaintly be used in non pb specific setups.
Ugg what a headache! I am going to grow old before I figure this all out and get it together correctly.
The HV5902 states it is for models with single-pump hydraulic system how can i tell if I have a single pump or something else?
Ford Tractor Hydraulic Pump, Cylinder, Lift Parts Adapters and Controls
vizi
   / 1970 ford 4000 3cyl diesel adding the HV4902 adapter plate #8
I'd count them :)
Live pto, and a pump in the center section, and not one at the bellhousing/ back of the engine, correct?
No pump on a front cover accy drive?
   / 1970 ford 4000 3cyl diesel adding the HV4902 adapter plate #9
Does your valve have/ show instructions for hooking up in a 2 hose configuration with a downstream load?
You know you will need input.. Leaves one connection for downstream reconnection. Ie, the plate only gives ya 2 hoses to make a looped circuit, out of plate, back into plate.
( ignore working ports for the moment )
   / 1970 ford 4000 3cyl diesel adding the HV4902 adapter plate #10
Not sure if any of this helps you with your HV4902 plate but I put the HV5902 on my (68) 3000. It's the same tractor as yours, just a little smaller. I would go from the (P)-pressure on the Tisco plate to the (In) on the DA valve. Then go (PB)-power beyond from the DA valve to the Tisco PB plate. Then I would take my return from the DA valve to the (T)-tank on the Tisco plate. I have my valve removed right now so I put a bypass hose on.
2019 KOMATSU D51PX-24 CRAWLER DOZER (A51246)
2019 KOMATSU...
Terex Loader Arm with Bucket (A51691)
Terex Loader Arm...
2004 MCI D4500 Passenger Bus, VIN # 1M8PDMPA54P056247 (A51572)
2004 MCI D4500...
YOKOHAMA - GALAXY 16.9-24 DIAMOND BUTTON TIRES (A53472)
YOKOHAMA - GALAXY...
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
2009 HINO 185 18FT BOX TRUCK (A52577)
2009 HINO 185 18FT...
