Cutting Red Willow bushes in pasture with skidsteer, Brush cutter or Scissor cutter?
   / Cutting Red Willow bushes in pasture with skidsteer, Brush cutter or Scissor cutter?
Holy Crap! that is impressive! My Bobcat S570 is only 1950 lbs lift so pretty limited for that kind of work.
   / Cutting Red Willow bushes in pasture with skidsteer, Brush cutter or Scissor cutter? #22
That is the ROC (rated operating capacity), a very conservative rating.
The tipping load is 3900 pounds, a better indicator of what it could pull out of the ground.
Your dealer should have a puller that you can rent.
   / Cutting Red Willow bushes in pasture with skidsteer, Brush cutter or Scissor cutter? #23
Before and after pictures of my field perimeter. If you don't pull them out, roots and all, the will grow back like the Medusa!
   / Cutting Red Willow bushes in pasture with skidsteer, Brush cutter or Scissor cutter? #24
I guess you've ruled out attaching a steel plate shield to the underside of your tractor. My pastures are so overgrown I should probably try that myself,
I could do that but I think I can either buy a mower for the skid steer and resell it or hire it done and not have to worry about damaging my equipment, After I get the willows down I am hiring the neighbor to come in with his big 4wd and brush disk and going to have him go over it a few times and get it to the point that I can maintain it with my equipment, I plan on planting corn on it and harvest it to feed deer over the winter.
   / Cutting Red Willow bushes in pasture with skidsteer, Brush cutter or Scissor cutter? #26
HD flail mower?
   / Cutting Red Willow bushes in pasture with skidsteer, Brush cutter or Scissor cutter? #27
Where at in MN?
Quality Forklift >> Quality Forklift
Rent that PT110 and have some fun. :thumbsup::thumbsup::thumbsup::D
That looks like the perfect setup! very nice! This land is up in the northwest corner in MN near a place caller Four Town, I am close to a deal on a cutter now but I am concerned with the weight of the mower on the front being my skidsteer is a wheel type and the ground stays damp around the willows bushes, It may be something I need to do with the ground froze or when it dries out this summer. The mower I am dealing on weighs just under 1600 lbs.
   / Cutting Red Willow bushes in pasture with skidsteer, Brush cutter or Scissor cutter? #29
If you haven't closed the deal, check this one: Grace Manufacturing | Home of the Tree Terminator
It is hinged at the top of the SSQA plate and the front wheel carries half the weight when mowing.
The wheel would definitely help in the soft ground, What do they sell for?
This is the one I was looking at: Open Front Industrial Brush Cutter
They are made close to me so no shipping charges.
2015 JLG Triple-L Flatbed T/A Trailer (A50324)
2015 JLG Triple-L...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A53472)
Kubota 24in Quick...
2012 ADDCO Arrowboard (A52377)
2012 ADDCO...
2015 Ford Explorer (A51694)
2015 Ford Explorer...
66in Light Material Bucket Skid Steer Connection (A53472)
66in Light...
