So the mice ate up a few wires and didn't leave me much to splice into.
This is to my gas gage sending unit. Not sure there is enough to solder onto. Can u buy these with a pigtail or is it possible to disassemble?
All advice welcome.
All advice welcome.
Use a broken off radio antenna to slide over the pins and pull them out. Resolder and push back in.
I'd solder them how they are but it takes some experience.
Walmart, can u believe it, for $6 in the auto section by the fuses.
HF also has the heat-shrink tubing kits for $5.
127 Piece Heat Shrink Tubing Set
And a pretty good heat gun to shrink it.
Heat Gun - Dual Temperature Heat Gun, 15W
Thanks Rick! I usually use the iron or a lighter to Srink it. But seeing how I've been doing more rewiring than I ever thought I would I should go with a real heat gun. Can't count all the wires I had to resolder on my old b7500 after they all melted after it overheated and blew the head.
