Wiring harness connector help
   / Wiring harness connector help #11
Get some heat shrink tubing and slide it down the new wire before you solder it. After solder has cooled, slip the tubing over the new joint and use a blow dryer to shrink it for new insulation.
Thanks guys! After. visiting a few auto stores that had no clue I picked up a small Soldering iron and did exactly what u said. I'm estimating there was about 3mm exposed so I soldered up, individually heat srinked, couple individual wraps with electrical tape then both wires wrapped with tape then large piece of heat srinked together then loom.
Resistance checked out and gas gage works again.
Guess I got lucky. Only had to do gas gage, one of the block temp gages and the washer fluid hose.
Fit that In between my major service interval. Changed hydraulic fluid (SUDT2), both filters, front axle, fuel filter, flushed radiator and adjusted the A/C belt. All that's left is the engine oil and I should be good for another 400 hrs assuming I can keep the mice away
   / Wiring harness connector help #13
Where'd you find a soldering iron? hahaha Radio Shack used to be my go-to place for that kind of stuff, but now we have nothing..... maybe Harbor Freight?
Walmart, can u believe it, for $6 in the auto section by the fuses.
   / Wiring harness connector help #16
yup.. HF has them too. or amazon. ;)
   / Wiring harness connector help #20
Thanks Rick! I usually use the iron or a lighter to Srink it. But seeing how I've been doing more rewiring than I ever thought I would I should go with a real heat gun. Can't count all the wires I had to resolder on my old b7500 after they all melted after it overheated and blew the head.
I used my fairly new HF Heat Gun a bunch a few weeks ago adding front and rear LED Light bars on my Polaris Ranger. Used HF shrink tubing at splices and wire connection on the light bars and power relays. Also added a Nautilus Bad Boy air horn and power relay to the Ranger.
I really like the two heat ranges on the HF Heat Gun.
2015 INTERNATIONAL 4300 26FT BOX TRUCK (A51222)
2015 INTERNATIONAL...
E-Z Trail 672 Head Cart (A50514)
E-Z Trail 672 Head...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
Chevrolet C8500 Flat Bed with a Moffet Kit (A52128)
Chevrolet C8500...
2018 ISUZU FTR 24FT BOX TRUCK (A51222)
2018 ISUZU FTR...
2014 CATERPILLAR 740B OFF ROAD DUMP TRUCK (A51242)
2014 CATERPILLAR...
