I switched the neutral on my float switch in a cistern
   / I switched the neutral on my float switch in a cistern #11
Not exactly a tractor job but a tractor did dig the hole for the cistern, so...
I put a float switch in the tank to shut the pump off if the water level gets too low. If I ran the hot wire to the switch (as is certainly standard) and the switch ever leaked then I have a potentially dangerous situation on my hands. A cistern with a 125VAC wire in it... and maybe or maybe not it will draw enough current to trip the breaker.. I didn't want to risk it so I ran the neutral to the switch and labeled the junction box in the crawl space as a reminder to me. What are your comments on this?
The cistern is 500 gallons, collects roofwater for a garden and has been in operation a couple of years. Here is the switch.
Series CFS2 | Cable Float Switch | Dwyer Instruments
Wrong , incorrect, immoral and illegal.
   / I switched the neutral on my float switch in a cistern #12
i thought that gfci held in the circuit by the line voltage. so if you want to make a circuit 60 volt for a item that requires 60 volt, do they make 60 volt gfci in 60 volt or what size gfci's do they make?
   / I switched the neutral on my float switch in a cistern #13
No, A GFI simply looks at the current going out and compares it with what is coming back. IF what is coming back is less, it assumes a leak to ground (through whatever fault) and shuts off.
   / I switched the neutral on my float switch in a cistern #14
Where is the pump ? In the tank or remote from the tank ???
The pump is outside the tank. A foot valve is in the tank.
   / I switched the neutral on my float switch in a cistern #16
The GFCI will only provide protection on the high voltage side of the transformer, everything on the high voltage side that is downstream of the GFCI, most importantly the pump.
   / I switched the neutral on my float switch in a cistern #17
Is the pump hard wired or plugged into an outlet ? Is the pump out in the weather or in a pump house? Before anyone answers your question they should know all the facts.
Pump is in the crawl space and is plugged in.
   / I switched the neutral on my float switch in a cistern #19
Then what I would do is put in a GFI outlet and wire this onto your float switch that you already bought plug.jpg
The deed is done - I switched polarity on the in-tank switch and installed a GFI receptacle. Thanks for the input and guiding me through my ignorance.
2014 Lamar Trailer (A55973)
2014 Lamar Trailer...
Booster Cables (A59230)
Booster Cables...
Brock 60'x26' Flat Bottom Grain Storage Tank (A57148)
Brock 60'x26' Flat...
1999 GMC C7500 S/A Dump Truck (A59230)
1999 GMC C7500 S/A...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Hustler super Z zero turn (A56859)
Hustler super Z...
