I switched the neutral on my float switch in a cistern
   / I switched the neutral on my float switch in a cistern #11
Not exactly a tractor job but a tractor did dig the hole for the cistern, so...
I put a float switch in the tank to shut the pump off if the water level gets too low. If I ran the hot wire to the switch (as is certainly standard) and the switch ever leaked then I have a potentially dangerous situation on my hands. A cistern with a 125VAC wire in it... and maybe or maybe not it will draw enough current to trip the breaker.. I didn't want to risk it so I ran the neutral to the switch and labeled the junction box in the crawl space as a reminder to me. What are your comments on this?
The cistern is 500 gallons, collects roofwater for a garden and has been in operation a couple of years. Here is the switch.
Series CFS2 | Cable Float Switch | Dwyer Instruments
Wrong , incorrect, immoral and illegal.
   / I switched the neutral on my float switch in a cistern #12
i thought that gfci held in the circuit by the line voltage. so if you want to make a circuit 60 volt for a item that requires 60 volt, do they make 60 volt gfci in 60 volt or what size gfci's do they make?
   / I switched the neutral on my float switch in a cistern #13
No, A GFI simply looks at the current going out and compares it with what is coming back. IF what is coming back is less, it assumes a leak to ground (through whatever fault) and shuts off.
   / I switched the neutral on my float switch in a cistern #14
Where is the pump ? In the tank or remote from the tank ???
The pump is outside the tank. A foot valve is in the tank.
   / I switched the neutral on my float switch in a cistern #16
The GFCI will only provide protection on the high voltage side of the transformer, everything on the high voltage side that is downstream of the GFCI, most importantly the pump.
   / I switched the neutral on my float switch in a cistern #17
Is the pump hard wired or plugged into an outlet ? Is the pump out in the weather or in a pump house? Before anyone answers your question they should know all the facts.
Pump is in the crawl space and is plugged in.
   / I switched the neutral on my float switch in a cistern #19
Then what I would do is put in a GFI outlet and wire this onto your float switch that you already bought plug.jpg
The deed is done - I switched polarity on the in-tank switch and installed a GFI receptacle. Thanks for the input and guiding me through my ignorance.
2023 JOHN DEERE XUV 590M S4 UTV (A59823)
2023 JOHN DEERE...
2019 Grove TMS500-2 40 Ton Hydraulic Truck Crane (A60460)
2019 Grove...
20FT X 12FT LIVESTOCK METAL SHED (A58214)
20FT X 12FT...
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
2023 GREAT DANE FLP-0024-00053 53FT FLATBED TRAILER (A59905)
2023 GREAT DANE...
2018 CATERPILLAR 326FL EXCAVATOR (A60429)
2018 CATERPILLAR...
