Box blade for BX2230
   / Box blade for BX2230 #11
I would probably go with the yellow one. Four teeth rather than three, and easily adjustable. Weighs more, and weight is important. I always have concrete blocks on top of mine...which is a 60 inch I use on the back of my B2910. I think I have had it on the back of my BX2200 but don't remember for sure.
The more important issue is getting your HP to the ground. My BX will spin its wheels rather than put the HP to the ground sometimes. When using my 72" landscape rake, the BX will stop moving (with wheels spinning) if I try to rake up hill, but my larger tractor with the same rake on it will move up the same slope with the rake engaged without any problem.
My guess is that whichever box blade you buy you will run into the same operating issues, whatever they might turn out to be. So why not buy the better of the two, which in my estimation is the yellow one...
Bill
   / Box blade for BX2230 #13
I like the idea of the orange model made more for my tractor, but am concerned whether it is heavy duty enough.
BX tractors are great machines but probably not that great pulling a Box Blade.
Except in really soft dirt, you need 100 pounds minimum of weight per foot of Box Blade width to be effective.
For "nasty clay" 125 pounds per foot would be preferable.
In lieu a Box Blade, consider a Piranha Tooth Bar for your bucket. For some, not all, jobs a good Tooth Bar on your bucket will be superior to a too-light Box Blade. A Piranha will cut moist clay easily.
I suggest you post the tasks you intend for your Box Blade for comments and implement alternatives.
PIRANHA VIDEO: piranha tooth bar - YouTube
   / Box blade for BX2230 #14
Here's my pick.
US Made including Made in USA Ripper Shanks and Cutting Edges.
The 48" Land Shark Box Blade is currently only $559 and the 60" is only $599.
Free shipping to a staffed commercial business or nearest supporting freight terminal within 1,000 miles of Newton, NC.
Travis
I would do most excavating in slightly moist soil as I realize how tough clay is. I work in a job with access to steel easily, so adding weight would be pretty easy. I assume that is what you are suggesting? The piranha bar is nice, but I also want to use the box blade for my gravel drive. Not sure how they do in snow?
I want to use the blade to do some landscaping and leveling where we added trenches in the yard last year for some drain tile, and to level out some dirt bike trails.
Here's my pick.
Travis
Travis - That looks nice. What is the height of the moldboard? I want to make sure I get decent lift/clearance. Thanks
   / Box blade for BX2230 #17
The BX2230 is rated for 680 lbs on the 3 pt at 24" and easily lifts my 48" BB. A really full box is a quite a load for it to pull, but it does good work grading and leveling. For small jobs and touch-up grading, the BX is easier to use than my larger equipment, even though it lacks position control. Bar tires help a lot when pulling a BB; I found the turfs couldn't pull very well. The turfs have been sitting unused ever since. If anyone wants a good deal on a virtually new set of BX rims and turf tires, send me a PM.
Box blade really isn't the best tool for snow. The box quickly fills up and the load must be dropped when you're going forward while pushing material going backward isn't a great plan... if you hit something it can really damage the tractor. Used mine for snow a few times but found a small scraper blade that is much better because it can windrow the snow to the side.
Unfortunate as I have turf tires on mine. I dont plan on doing major excavating with it however. Geez, maybe a simple back blade as bcp pointed to with the piranha teeth may be the way to go
   / Box blade for BX2230 #19
Thanks.
The moldboard height is right at 16".
We will be adding more detailed specifications soon.
Travis
Here is the product video:
   / Box blade for BX2230 #20
Maybe others will relate their own experiences but here's mine. The front bucket can do a fair job of lifting, carrying and digging - a toothbar helps - but I never had great success trying to level out surfaces with it. By backgrading with it you can smooth loose soil nicely but it wants to follow the surface, not level it. Don't have a Piranha bar but expect it would help with scratching the soil loose.
That left me with the predicament that the box blade is much better for dirt work while the scraper blade does well with snow and light grading of loose material such as gravel.
Checking Craigs list in our area frequently turns up old 5 ft scraper blades at pretty cheap prices. A bit big for the BX - esp with turfers - but workable. Seldom see used 48" box blades though. If I had to get one new item - instead of a Piranha or tooth bar, but that's just me - I'd go for the box and look for a deal on a used scraper when there was a spare $100 on hand.
RCcar RC-G2.0 Electric Golf Cart, New! (A52384)
RCcar RC-G2.0...
2020 MDB UT125KPLUS FLAIL MOWER (A51247)
2020 MDB...
2013 Chevrolet Silverado 1500 4x4 Ext. Cab Pickup Truck (A52377)
2013 Chevrolet...
2018 Chevrolet Silverado 2500HD Knapheide Service Truck (A51692)
2018 Chevrolet...
Dixie Chopper LT2000 50in. Zero-Turn Lawn Mower (A53117)
Dixie Chopper...
2018 HINO CONVENTIONAL TYPE TRUCK (A52472)
2018 HINO...
