Alternator is overcharging, need to rebuild it!!!
   / Alternator is overcharging, need to rebuild it!!!
I agree with the baking soda in warm water to clean up all the corrosion.Been doing this for years.I also coat my terminals with either grease or silicone dieletric compound.As far as the corrosion all over the holdown and all are you sure its not from the batteries vent area rather than the terminals that is causing it
In this case, the hold down bar is approx 2.5" away (going from memory, at work now!) from the vents and you should see the beautiful dome of corrosion on the bar. In fact, the bar has been eaten away with this mess and I will need to make a new hold down bar.
I'd use grease for the terms but due to the amount of dirt/dust I work in, it'd get nasty I'm sure. I'll pick up a batt term spray on my way home today. I'll set myself a reminder to do that actually. Thanks for the reminder!
   / Alternator is overcharging, need to rebuild it!!! #22
gob some regular grease around the base of the terminal onto the battery, and attach the cables. Slather grease over the cable ends and you'll be good to go for a long time.
   / Alternator is overcharging, need to rebuild it!!! #23
I was at the auto parts today and saw several brands of terminal spray to eliminate corrosion and some brands of protector stuff to keep it from happening too. The protector stuff came in both spray or brush on. I'll just go with the felt rings and some goop to keep it under control.
Like I said when this standard battery gives up the ghost, an AGM goes in. If the regular battery wasn't new and mine already, I'd swap it out right now.
   / Alternator is overcharging, need to rebuild it!!! #24
If the excide battery is still in it replace it with an interstate and put new terminal connectors and do away with the bands... end of issues.
KOMATSU PC360LC-11 EXCAVATOR (A60429)
KOMATSU PC360LC-11...
INGERSOLL RAND G25 GENERATOR (A58216)
INGERSOLL RAND G25...
CATERPILLAR 299D3 SKID STEER (A60429)
CATERPILLAR 299D3...
2012 KOBELCO SK170-9 ACERA MARK 9 EXCAVATOR (A60429)
2012 KOBELCO...
2014 Ford F-550 (A55973)
2014 Ford F-550...
2020 CATERPILLAR 303.5E2 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
