Alternator is overcharging, need to rebuild it!!!
   / Alternator is overcharging, need to rebuild it!!!
I agree with the baking soda in warm water to clean up all the corrosion.Been doing this for years.I also coat my terminals with either grease or silicone dieletric compound.As far as the corrosion all over the holdown and all are you sure its not from the batteries vent area rather than the terminals that is causing it
In this case, the hold down bar is approx 2.5" away (going from memory, at work now!) from the vents and you should see the beautiful dome of corrosion on the bar. In fact, the bar has been eaten away with this mess and I will need to make a new hold down bar.
I'd use grease for the terms but due to the amount of dirt/dust I work in, it'd get nasty I'm sure. I'll pick up a batt term spray on my way home today. I'll set myself a reminder to do that actually. Thanks for the reminder!
   / Alternator is overcharging, need to rebuild it!!! #22
gob some regular grease around the base of the terminal onto the battery, and attach the cables. Slather grease over the cable ends and you'll be good to go for a long time.
   / Alternator is overcharging, need to rebuild it!!! #23
I was at the auto parts today and saw several brands of terminal spray to eliminate corrosion and some brands of protector stuff to keep it from happening too. The protector stuff came in both spray or brush on. I'll just go with the felt rings and some goop to keep it under control.
Like I said when this standard battery gives up the ghost, an AGM goes in. If the regular battery wasn't new and mine already, I'd swap it out right now.
   / Alternator is overcharging, need to rebuild it!!! #24
If the excide battery is still in it replace it with an interstate and put new terminal connectors and do away with the bands... end of issues.
2018 Ram 3500 4x4 Service/Utility Truck, VIN # 3C7WRTCL0JG387527 (A57453)
2018 Ram 3500 4x4...
KUBOTA SVL75 ENCLOSED CAB (A52706)
KUBOTA SVL75...
2007 FORD F-150 XL TRITON (A58214)
2007 FORD F-150 XL...
2006 Mercedes-Benz Unimog 405 4x4 Flatbed Truck (A56858)
2006 Mercedes-Benz...
2005 Volvo VNL Truck, VIN # 4V4N19TGX5N374968 (A57453)
2005 Volvo VNL...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
