Oil Presusre and Water Temperature Gauge Add-On
   / Oil Presusre and Water Temperature Gauge Add-On
Here is the water temp and oil pressure lines connected to the engine block.
Sent from my iPhone 2.0 using TractorByNet
Sorry about that. Next time I'm on the computer I'll rotate it.
<CGImageProvider 0x15e014a0>
   / Oil Presusre and Water Temperature Gauge Add-On #15
No problem, thanks for posting.
I've decided against mounting the gauges on hood of the tractor... Once they are finally mounted in the "cockpit" I'll post them too, right side up. :D
Jeff
How do you rotate pictures? I have a few that need it. Thanks
The only way I know is to rotate on my pc then re-upload to my message. I have not found a way to do it within TBN.
Finally finished the installation today. I'll get a night photo another time.
50 PSI Oil and 165°F water no load. Matches about the 1/4 mark on the factory gauge.
   / Oil Presusre and Water Temperature Gauge Add-On #20
They look great.
Aren't you worried about hitting them with your knees?
UNUSED PAIR OF 76" SLIP ON FORK EXTENSIONS (A57193)
UNUSED PAIR OF 76"...
2025 Groundhog RH14G Vibratory Articulated Tandem Smooth Drum Roller (A55851)
2025 Groundhog...
(2) USED 700 LB TRAILER BRAKE AXLES (A57192)
(2) USED 700 LB...
2019 GEHL RT105 SKID STEER (A52707)
2019 GEHL RT105...
2014 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2014 Ford F-150...
2006 Vermeer BC1000XL Towable Brush Chipper (A55851)
2006 Vermeer...
